圖解 riva tuner 軟改 ati FireGL 7350
Ati 全系列軟改大致有二
一.使用破解驅動 直接跳到步驟11
二.使用riva tuner
如果嫌使用破解驅動沒什麼動手改的樂趣
那也可使用 底下 riva tuner 的方式自己手動破解驅動
1. 下載驅動https://a248.e.akamai.net/f/674/9206...2kxp-36758.exe
2.下載 riva tune final
http://downloads.guru3d.com/download.php?det=163
3.執行驅動
選擇解壓縮-----指定要解壓的位置
----當跳出安裝畫面時,選擇不安裝
4.安裝riva tuner final 版
5.進入 riva tuner 的子目錄
C:\Program Files\RivaTuner v2.0 Final Release\PatchScripts\ATI\SoftFireGL\1024+
6. 打開SoftFireGL w2k.rts (最好先複制)
7.用底下這些數值蓋掉並存檔
存檔後請自行改一個名字
[Common]
SrcFile = ati2mtag.sys
BakFile = ati2mtag.old
HlpFile = SoftR9x00.rth
MakeCRC = 1
Packed = 1
;common script for 663X+
DstVar0 = force FireGL V3300 capabilities
DstVar1 = force FireGL 5200 capabilities
DstVar2 = force FireGL 7350 capabilities
DstVar3 = force MOBILITY FireGL V5200 capabilities
DstVar4 = force MOBILITY FireGL V7200 capabilities
DstVar5 = force MOBILITY M54GL capabilities
Src0 = 81 FA 00 80 00 00 75 16 A9 00 00 00 08 74 0F A9 00 00 00 10 75 08
Dst0 = 81 FA 00 80 00 00 90 90 A9 00 00 00 08 90 90 A9 00 00 00 10 90 90
Src1 = 83 F8 40 75 1D 66 81 BD 00 00 FF FF 02 10 75 00 0F B7 85 FE FE FF FF
SCM1 = FF FF FF FF 00 FF FF FF 00 00 FF FF FF FF FF 00 FF FF FF FF FF FF FF
Dst1_0 = 0F B7 85 FE FE FF FF 66 25 00 00 66 0D 52 71 66 89 85 FE FE FF FF 90
Dst1_1 = 0F B7 85 FE FE FF FF 66 25 00 00 66 0D DA 71 66 89 85 FE FE FF FF 90
Dst1_2 = 0F B7 85 FE FE FF FF 66 25 00 00 66 0D 0F 71 66 89 85 FE FE FF FF 90
Dst1_3 = 0F B7 85 FE FE FF FF 66 25 00 00 66 0D C4 71 66 89 85 FE FE FF FF 90
Dst1_4 = 0F B7 85 FE FE FF FF 66 25 00 00 66 0D 03 71 66 89 85 FE FE FF FF 90
Dst1_5 = 0F B7 85 FE FE FF FF 66 25 00 00 66 0D 44 71 66 89 85 FE FE FF FF 90
Src2 = FF 74 24 08 E8 83 75 FF FF A8 04 75 0B 6A 2E
Dst2 = FF 74 24 08 E8 83 75 FF FF A8 04 90 90 6A 2E
Src3 = 85 BE B4 00 00 00 75 3A 6A 3C
Dst3 = 85 BE B4 00 00 00 90 90 6A 3C
Src4 = E8 90 93 FF FF 85 C0 74 2E
Dst4 = E8 90 93 FF FF 85 C0 90 90
Src5 = E8 E0 50 FF FF F6 C4 20 74 08
Dst5 = E8 E0 50 FF FF F6 C4 20 90 90
Src6 = 85 C0 74 2F 50 8B 47 04
Dst6 = 85 C0 EB 2F 50 8B 47 04
Src7 = 8A 85 04 FF FF FF
Dst7 = B0 80 90 90 90 90
以上數值引自 http://www.guru3d.com/
adapted from http://www.guru3d.com/
8.執行這個檔-----選擇要改的顯卡型號----選擇 continue
9.
到剛剛 ati 驅動程式解壓縮的地方
進入以下的子目錄C:\ati\FGL\firegl-win2kxp-36758\Driver\2KXP_INF\B_36301
開啟ati2mtag.sy_ 檔
或者 .sys
10.破解完成
11.
本步驟可延後 沒差
進riva tuner
點擊上層的 customiz
點擊第一個 low level setting
在 PCI DEVICE DRIVERS 改成 7350
Unlock Professional Setting 選項打勾
12. 進控制台 ----系統-----硬體----裝置管理員------顯示卡
-----點擊 ati 的驅動式-------更新驅動程式
換掉 ATi的二個驅動程式
指定成 7350 的二個驅動程式
必須二個都換掉後才能重新開機
(也可使用解除安裝二個驅動程式後 再使用變更硬體掃瞄)
13.重新開機
改卡完畢
後邊微調設定自己玩 ^^
