All Windows 7 versions are supported.
Windows Server 2008 R2 Enterprise, etc, supported.
RemoveWAT removes WAT (Windows Activation Technologies) completely from the OS, whilst still retaining OS genuine status and receiving all updates.
You will still pass the genuine check (WGA).
Disables activation completely but does nothing to the validation.
There will be no windows activation section in control panel.
Windows Activation Technologies will be gone.
No slmgr, no nags, no prompts.
What's new in version 2.2.5 :
renames slmgr on x64 aswell
Works on unicode systems
silent mode with /s switch
UI tweaked slightly
No reboot neccessary
Passes WGA on X64
This is a little tool I put together to remove WAT (Windows Activation Technologies) completely from the OS, whilst still retaining genuine status and receiving all updates (optional aswell). You can also pass the genuine check in things like Windows Defender. There will be no windows activation section in control panel (thanks to nononsence)
下載點:
http://www.megaupload.com/?d=XEA05TX8
請服用! 好用的話~給我個感謝吧
