Reg Organizer 5.40 Beta 1
INFO
Download FileSonic
INFO
Reg Organizer - is a multipurpose program for cleaning the registry and its services, as well as work with configuration files. Allows you to view and edit the registry, preview the imported reg-files (including from Windows Explorer). Registry search feature provides the ability to make a deep search in the registry, finding all the keys related to the application. Reg Organizer also supports managing configuration files of various types.
Key features:
• Registry Editor to view and edit the registry to perform various operations c keys and values of the registry, export and import the keys, etc.
• Clean Sweep Registry to search for unnecessary registry entries, as well as to find and fix problems in the registry.
• Registry search feature can find all keys related to a certain application and delete them if necessary. This is useful, for example, when an application that has no uninstall and then delete it "manually" in the registry are unnecessary entries, which can lead to incorrect operation of other programs. At the same time, Reg Organizer provides the deepest search and can often find even those keys associated with this application, which are not found in other similar programs.
• Defragmenting and compressing the registry. These procedures can increase the speed of the registry and, consequently, the performance of your system as a whole.
• The ability to change many of the "fine tuning" Windows (tweaks). In particular, you can speed up your system, ordering system to use a larger cache size or by unloading unused libraries, memory, etc.
• Ability to obtain information about any registry key and monitor changes in it.
• Preview of the registry files (*. reg) before adding their contents, including directly from Windows Explorer. When viewing an imported reg-file contents in a tree structure that allows us to visualize all keys that are imported into the registry.
• View and edit startup programs, ie applications that are loaded at Windows startup or logon.
• The search and replace in the registry is a convenient tool for finding (and, if necessary, change) key or registry keys that meet the search criteria.
• Built-in software uninstaller. It can make a "snapshot" of the system before and after installation, then you can completely "roll back" system changes, as if the application has not been established.
• Tool "Cleaning discs" allows automatic cleaning of your hard drive from a variety of junk files, as well as search for and fix invalid shortcuts.
• Manage configuration files. The program Reg Organizer you can open and edit (add, edit, delete keys / sections) INI-files of various programs.
Download FileSonic
代碼:
http://www.filesonic.com/file/ZNZbIcl/
