【檔案名稱】:PowerISO v4.9 強大映像文件處理工具
【軟體語言】:多國語言
【軟體類型】:映像文件處理工具
【檔案格式】:RAR
【檔案大小】:2.27MB
【壓縮密碼】:無
【上傳空間】:Filepost/Wupload/Crocko/Filesonic/FreakShare
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
[font=標楷體]PowerISO是一個功能強大的CD / DVD / BD映像文件處理工具。它可以建立,編輯,解壓,轉換,壓縮,加密和分割 ISO,BIN,NRG,CDI,DAA 映像檔案。內建虛擬光驅可以加載映像文件實時運行。它可以處理幾乎所有的CD / DVD / BD的圖像文件,包括ISO和BIN文件。PowerISO提供的所有功能於一體的解決方案。你的ISO文件,光盤映像文件,你可以做的每一件事。
PowerISO 掛載DAA映像檔所需的虛擬光碟軟體,網路上下載的遊戲和大型軟體很多都是 DAA 格式的映像檔(因為其壓縮比高, 檔相對的小),這些檔案用 Daemon tools 是沒辦法開啟的,這時候就需要 PowerISO。
PowerISO支援ISO,BIN,NRG,IMG等幾乎所有常見的映像檔案。支援右鍵選單直接將檔案或資料夾製作成ISO檔,相當方便。
Main Features:
●Support almost all CD / DVD / BD-ROM image file formats (ISO, BIN, NRG, CDI, DAA and so on).
What is DAA file? DAA file (Direct-Access-Archive) is an advanced format for image file, which supports some advanced features, such as compression, password protection, and splitting to multiple volumes.
●Open and extract ISO file. You can extract ISO file with a single click.
●Burn ISO file to CD, DVD, or Blu-Ray disc. PowerISO is a professional burning software. With this tool, you can create Audio CD, Data CD, Data DVD, Video DVD or VCD. PowerISO also supports Blu-Ray burning.
●Burn Audio CD from MP3, FLAC, APE, WMA, or BIN files.
●Rip Audio CD to MP3, FLAC, APE, WMA, or BIN files.
●Create ISO file or BIN file from hard disk files or CD / DVD / BD discs.
●Edit ISO image file directly.
●Mount ISO file with internal virtual drive. PowerISO can mount all popular disc image files to built-in virtual drive.
●Convert image files between ISO / BIN and other formats. PowerISO can not only convert BIN to ISO, but also convert almost all image file formats to standard ISO image file.
●Create bootable USB drive. PowerISO allows you to setup Windows through USB drive.
●Make bootable ISO file and create bootable CD, DVD disc.
●Support both 32-bit and 64-bit Windows.
●Can be used easily. PowerISO supports shell integration, context menu, drag and drop, clipboard copy paste...
What's New:v4.9(Nov 15, 2011):
+) Support Windows 7 taskbar progress bar.
+) Support ISZ file.
+) Improve UDF file support.
*) Some minor bug fixes and enhancements
Supported operating systems:
32-bit Windows: Windows 98, Me, 2000, XP, 2003, Vista, 2008, 7
64-bit Windows: Windows XP, 2003, Vista, 2008, 7
Supported languages:
English, Arabic, Armenian, Belarusian, Bosnian, Bulgarian, Chinese Simplified, Chinese Traditional, Croatian, Czech, Danish, Dutch, Farsi, French, German, Greek, Hungarian, Italian, Japanese, Korean, Lithuanian, Malay, Norsk, Polish, Portuguese, Russian, Serbian, Slovak, Slovenian, Spanish, Swedish, Thai, Turkish, Ukrainian, Vietnamese
[/font]
下載地址: (等待5秒再按下右上的Skip AD/HIDE FRAME就可到下載頁)
Filepost載點
Wupload載點
Crocko載點
Filesonic載點
Freakshare載點
下載技巧:
可用JDownloader下載
JDownloader載點 || JDownloader後備載點
各空間等待時間為10至30分鐘,本身是該空間之Premium用戶則無以上問題
請勿使用續傳軟體抓取(如迅雷、Flashget等等),以免抓取失敗或抓到不完整檔案
[更新]WinRAR 4.0.1 Pro 32bit&64bit
4.0.1載點 || 4.0.1後備載點
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
1.僅供網路測試無任何販售行為及獲得任何利益!請於測試完後24小時以內將檔案刪除!
2.請支持正版!本檔案的提供純為試看用途,請勿作商業上之用途!!!!請於下載完後24小時以內將檔案刪除!!!
【軟體語言】:多國語言
【軟體類型】:映像文件處理工具
【檔案格式】:RAR
【檔案大小】:2.27MB
【壓縮密碼】:無
【上傳時間】:30天無下載自動刪檔
【軟體簡介】:
Main Features:
Filepost載點
Wupload載點
Crocko載點
Filesonic載點
Freakshare載點
下載技巧:
可用JDownloader下載
7zip 免安裝版
7zip載點 || 7zip後備載點
免責聲明:
