小弟想請教各位前輩的是我的Phenom X4 9500核心頻率應該有2.2Ghz,
但是使用CPUZ卻意外發現,倍頻的部分竟然只有5.5,因此核心竟然只剩下
1.1Ghz!?(如下表)這是怎麼一回事呢?
小弟用的是Vista 64bit Businese版,主機板則是M3A,沒有超頻。
Processor 1 ID = 0
Number of cores 4 (max 4)
Number of threads 4 (max 4)
Name AMD Phenom X4 9500
Codename Agena
Specification AMD Phenom(tm) 9500 Quad-Core Processor
Package Socket AM2+ (940)
CPUID F.2.2
Extended CPUID 10.2
Brand ID 10
Core Stepping DR-B2
Technology 65 nm
Core Speed 1100.1 MHz
Multiplier x FSB 5.5 x 200.0 MHz
HT Link speed 1800.2 MHz
Stock frequency 2200 MHz
Instructions sets MMX (+), 3DNow! (+), SSE, SSE2, SSE3, SSE4A, x86-64
L1 Data cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L1 Instruction cache 4 x 64 KBytes, 2-way set associative, 64-byte line size
L2 cache 4 x 512 KBytes, 16-way set associative, 64-byte line size
L3 cache 2 MBytes, 32-way set associative, 64-byte line size
FID/VID Control yes
FID range 5.0x - 11.0x
Max VID 1.250 V
Package Type 0x1
Model 95
String 1 0x2
String 2 0x0
Page 0x0
Attached device PCI device at bus 0, device 24, function 0
Attached device PCI device at bus 0, device 24, function 1
Attached device PCI device at bus 0, device 24, function 2
Attached device PCI device at bus 0, device 24, function 3
Attached device PCI device at bus 0, device 24, function 4
Processor 1 ID = 0
Codename Agena
CPUID F.2.2
Extended CPUID 10.2
Brand ID 10
Core Stepping DR-B2
Technology 65 nm
FID/VID Control yes
Max VID 1.250 V
Package Type 0x1
Model 95
String 1 0x2
String 2 0x0
Page 0x0
