一套OS 可共用2台電腦嗎?
h88154921
請問網友:
我有2台電腦可以共用一套 Windows 7 旗艦版-盒裝完整版或是隨機版,2台電腦不會同時開機;
2台註冊同一人.謝謝!
ST-15K.3
我是恐龍..
以法規來說還是違法喔
h88154921
養狗跟主人;養貓跟屋子,老一輩常說.
Windows 7 旗艦版-盒裝完整版跟人走;隨機版跟主機走.
盒裝完整版,可以在不同主機上使用.
fjh3uioc
一套OS 可共用2台電腦嗎? X
2台電腦可共用 一套OS嗎? O
Blank
如果Microsoft有給兩張序號貼紙就可以, 懂了吧.
shingowu
盒裝完整版可以換電腦使用,但總數要跟授權數量一樣。
隨機版只能跟主機板走,機板掛了就等於要重買了。
limhh
只有Family Pack的Win7可以安裝3架電腦。其他版本都只能安裝在一架電腦上,不過你可以安裝多一次到同一架電腦里的虛擬機里。
INSTALLATION AND USE RIGHTS.
a. One Copy per Computer. You may install one copy of the software on one computer. That computer is the “licensed computer.”
b. Licensed Computer. You may use the software on up to two processors on the licensed computer at one time. Unless otherwise provided in these license terms, you may not use the software on any other computer.
c. Number of Users. Unless otherwise provided in these license terms, only one user may use the software at a time.
d. Alternative Versions. The software may include more than one version, such as 32-bit and 64-bit. You may install and use only one version at one time.
So that pretty much states how many computers you can install Windows 7 on! ONE! Now if you have the Family Pack, you can clean install or upgrade up to 3 PCs.
Note that in Windows 7, you can also uninstall Windows 7 from one PC and install it on another.
The one caveat that is pretty neat is the fact that you can install one more copy of Windows 7 on the same licensed machine in a virtual machine. However, it has to be on the same computer. Here is the official text:
d. Use with Virtualization Technologies. Instead of using the software directly on the licensed computer, you may install and use the software within only one virtual (or otherwise emulated) hardware system on the licensed computer. When used in a virtualized environment, content protected by digital rights management technology, BitLocker or any full volume disk drive encryption technology may not be as secure as protected content not in a virtualized environment. You should comply with all domestic and international laws that apply to such protected content.
h88154921
Windows 7旗艦版 盒裝完整版
MICROSOFT 軟體授權條款中有一條:安裝與使用權利.
授權電腦 貴用戶於同一時間最多僅得於授權電腦之兩個處理器上使用軟體.除非本授權條款另有規定,
否則 貴用戶不得在任何其它電腦上使用軟體.
兩個處理器上使用???
