**抱歉..一時還來不及打中文,不過就委屈大家吧
Dear All,
Avantium is proud to release the world's first DDR3-2000 3GB/6GB triple
channel kit, The Leopard Series!!Previously, I have revealed the chip (samsung's SEC-hcfo) along with its
great performance here. Now, Avantium has just done for all their retail
packaging and company is all ready to go for all the users' reference!!
Here I would like to introduce you the full retail pack.
The package of 2gb x3 triple channel kit itself; please note that 1gb x3
triple channel kit is also identical looking.
back side of package and info
the Specifications on both 1gb/2gb kits
The chip what Leopard series used.
Inside of heatsink, I suggest company use "non-sticky high quality
silicon thermal pad";) so users can decide if they want to use stock HS or
custome HS.:)
The close picture of memory/heatsink
if you are wondering about warranty and the qualification how this memory
can do, here is the innformation regarding all.
As we can see the the information side, it all true about how I test them
with spec. mentioned You might have luck to draw the pack lot more better
than what I test, basically all these kits have been hand-pick by me and
at least will show identical results like you see now .
Certainly the testbed may vary from case to case interms of hardware
components everyone has; however, Avantium will not guaranteed how much
you can overclock from this great product. Yet, you will definite satisfy
what you have. I promise.
Let's look at what I did on the Asus Rampage II Extreme:
2D:
Vdimm : 1.81v real DDR3-2000 8-8-8/7-22-1t
4g and 4.2g
3D under windows XP sp3:
I understand that currently other manufactures will have DDR3 2000
triple chaneel pack soon or even showed up, but I bet the "quantity"
would be very limited,however,
Avantium will not out of stock or even limited in terms of quantity.
More over, we really guaranteed that what you see will be equal to what
you will get.
Dear All,
custome HS.:)
2D:
4g and 4.2g
you will get.
