OCCT PT 3.0.2.b02 available !
Changelog :
CPU:Linpack now supports Hyperthreading. Just make sure the HT checkbox is checked
The "Hyperthreading as dual-core" checkbox as been renamed as "Hyperthreading". Simpler, and much easier to understand.
The Hyperthreading Checkbox is now checked by default for the CPU:OCCT and CPU:Linpack tests if your CPU supports HT. It will only be so on the first run, of course. If you uncheck it, OCCT will remember it.
Enjoy !
http://www.ocbase.com/download.php?fileext=beta
Changelog :
Enjoy !
