NTLite 無人值守作業系統安裝光碟製作工具,類似 nLite 的新一代版本工具,NTLite 可將重灌安裝光碟或 ISO 映像檔解壓縮於資料夾,再以此軟體加入資料夾或 WIM 軟體,功能有自訂線上安裝專案、新增或移除 Windows 元件、本機硬體檢查清單、驅動程式/更新檔/語言檔整合、優化設定、無人值守設定、額外安裝應用程式等等...自訂完成後可以儲存為 ISO 光碟映像檔,建立個人化和優化的 Windows 版本以便製作在無人值守狀態下的重灌光碟。
NTLite 也讓您能夠調整您目前正在使用的作業系統。然而,您應該牢記,移除模組將可能導致系統損毀,只能透過重新安裝作業系統來修復。
在開始任何進一步之前,請記住,如果您正在執行較舊的 Windows 版本,您應該使用 nLite(免費),因為 NTLite 僅支援 Windows 7 以後的版本。
【軟體名稱】:NTLite 1.0.0.3600 中文版 - 無人值守重灌光碟製作工具
【軟體大小】:20.7 MB(解壓後)
【作業系統】:Windows 7 / 7 64 bit / 8 / 8 64 bit / 10 / 10 64 bit
【官方網站】:https://www.ntlite.com/
【語言種類】:正體中文
本版本變更:
New
General: Win10 Redstone support (RS1 14257.1000)
Components: Network Discovery compatibility option
UI: Ukrainian translation. Thx MrHelgi!
Upgrade
Components: Event Viewer and Event Log Service split
Components: IME languages split
Components: Chinese split into Simplified and Traditional
Components: French (Canadian) split
Components: Keyboard removal for kept languages unlocked
Components: Showing all referenced compatibilities in component description
Components: Wildcard support for the compatibility file protection
Unattended: Product key now also used on Welcome screen
Unattended: Added ‘Recovery’ partition type
UI: Individual removed MB size per component on Apply removal progress
Fix
Components: ‘Disk Management’ was dependent on ‘Virtual Disk Support’
Components: ‘Media Player’ removal was causing IE Flash playback crash
Components: ‘US Dvorak’ keyboards added to Recommended compatibility (breaks cpanel input)
Components: ‘On Screen Keyboard’ was dependent on ‘Tablet PC’
Components: ‘Internet Explorer Engine’ error 5 during removal
Components: ‘Windows Store’ was causing OOBE reboot loop if not autologged-in
Components-Win7: ‘Network Access Protection’ was needed for ‘Network Center’
Unattended: ‘Join Domain’ was not automatically logging in
UI: Unattended page filter crash
載點:(解壓密碼:zhtwnet.com)
下載連結→ [按此下載]
【軟體大小】:20.7 MB(解壓後)
【語言種類】:正體中文
本版本變更:
New
Upgrade
Fix
下載連結→ [按此下載]
