D26 MANTA RAYS XT
Features:
- Base on D26 bios structure
- CPU Interface Table 166 & 200 MHz FSB: (ABIT Stock ROMSIP)
- DISABLE CPU Interface : Unchanged
- ENABLED CPU Interface : Improved 3D Handling & Bandwith Efficiency multiplier lower than 10
Bandwith Peak @ Multiplier 10.5
- Vcore same as D23 3D Fire R1 & R2
- New Small ABIT Logo at Boot Up
- 3D Fire Ingredients : Included
- Bios Layout : Manta Rays XT Edition
- CPU Disconnect Function Patch as Recomended by nVidia Tech
- Side Band Addressing : Enable by Default ( Depends on VGA Driver. It might overwrite the setting to Disable)
- Dimm Driving Stregth & Slew Rate : Stock ABIT Configuration
- Alpha Memory Timing : Stock ABIT Configuration
- AMD XP Mobile -> Renamed to AMD Athlon XP-M for Athlon Mobile User
- New Full Screen Logo on BootUp by HouseRat@OcForums.com( Press Tab to show POST screen , Press Delete to enter Bios)
- Improve 3DMark2001SE & 3D Application stability at high FSB
- SATA Bios Version 4247
- Soft L12 for Unmodded Tbred & Mobile
a)Command Per Clock Enabled
http://forum.abit-usa.com/attachment.php?s...=&postid=421118
http://www.geocities.com/nastechxtreme2/D2...antaRays-XT.zip
http://home.doramail.com/tictac/D26-MantaRays-XT.zip
b)Command Per Clock Disabled
http://forum.abit-usa.com/attachment.php?s...=&postid=421121
http://www.geocities.com/nastechxtreme2/D2...Rays-XT-CPC.zip
http://home.doramail.com/tictac/D26-MantaR...Rays-XT-CPC.zip
taitac 的網站中還有其他 BIOS. 請自行選擇.
http://s6.invisionfree.com/underclock/inde...php?showtopic=9
補充:
Command Per Clock (CPC) enable:
記憶體讀取效能更好, 但不宜超高頻的情況下使用 (over 230 mhz)
CPC Disable:
在超高頻的情況下增強了穩定度,特別是跑雙面 512ram 的時候.
當然, ram 的讀取效能會降低.
個人認為這版的好處是不加壓也可以超頻.
XP2000+ @200 x 10
Kingmax ddr 400 5-3-3-2.5
NF7 v2.0
hec 300W
Maxtor 40G 7200rpm
Fx5200
Features:
補充:
CPC Disable:
當然, ram 的讀取效能會降低.
個人認為這版的好處是不加壓也可以超頻.
XP2000+ @200 x 10
NF7 v2.0
hec 300W
Maxtor 40G 7200rpm
Fx5200
