似乎一切的錯誤都是從我開啟自動更新開始
開啟自動更新後呢,我首先發現我的格式工廠壞掉了(重新安裝格式工廠也沒有用)
於是GOOGLE後發現跟NET Framework有關西,想說會不會是因為在更新,所以出問題,於是從開機後
我的小紅傘就爆了(軟體主視窗無法開啟,但是右鑑的掃瞄功能正常)
於是我發現我電腦裡的NET Framework 1.1~40通通無法安裝或移除,所以上網找到這個工具
.NET Framework Cleanup Tool 全部移除後仍無法安裝....
這是1.1無法安裝的訊息
這是2.0無法安裝的訊息
這是3.0無法安裝的訊息
這是3.0的錯誤紀錄
4.0也無法安裝,這是錯誤紀錄
然後想說好像跟MSXML 還有c++(小紅傘無法啟動)有關,所以我就打算把他們移除
結果也不行....
以下是我電腦無法安裝,也無法移除的程式(打x的軟體)
ps 掃過毒了,沒有中毒
這是1.1無法安裝的訊息
這是2.0無法安裝的訊息
這是3.0無法安裝的訊息
這是3.0的錯誤紀錄
[06/22/11,11:33:24] MSXML 6.0 剖析器: [2] Error - file does not exist: e:\a549c1633109490191b2d5eddc15\.\wcu\msxml\msxml6.msi
[06/22/11,11:33:24] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467259.
[06/22/11,11:33:26] Microsoft .NET Framework 2.0: [2] Error - file does not exist: e:\a549c1633109490191b2d5eddc15\.\wcu\dotnetframework\dotnetfx.exe
[06/22/11,11:33:26] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467259.
[06/22/11,11:33:26] MSXML 6.0 剖析器: [2] Error - file does not exist: e:\a549c1633109490191b2d5eddc15\.\wcu\msxml\msxml6.msi
[06/22/11,11:33:28] WapUI: [2] DepCheck indicates MSXML 6.0 剖析器 is not installed.
[06/22/11,11:33:29] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0 is not installed.
[06/22/11,11:53:42] MSXML 6.0 剖析器: [2] Error - file does not exist: e:\d81637a2ee95e247cc\.\wcu\msxml\msxml6.msi
[06/22/11,11:53:42] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467259.
[06/22/11,11:53:44] Microsoft .NET Framework 2.0: [2] Error - file does not exist: e:\d81637a2ee95e247cc\.\wcu\dotnetframework\dotnetfx.exe
[06/22/11,11:53:44] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467259.
[06/22/11,11:53:45] MSXML 6.0 剖析器: [2] Error - file does not exist: e:\d81637a2ee95e247cc\.\wcu\msxml\msxml6.msi
[06/22/11,11:53:45] setup.exe: [2] ISetupComponent::Pre/Post/Install() failed in ISetupManager::InternalInstallManager() with HRESULT -2147467259.
[06/22/11,11:53:47] WapUI: [2] DepCheck indicates MSXML 6.0 剖析器 is not installed.
[06/22/11,11:53:47] WapUI: [2] DepCheck indicates Microsoft .NET Framework 2.0 is not installed.
4.0也無法安裝,這是錯誤紀錄
OS Version = 5.1.2600, Platform 2, Service Pack 3
[6/22/2011, 11:58:49]OS Description = WinXP - x86 Professional Service Pack 3
[6/22/2011, 11:58:49] OS Version Information
[6/22/2011, 11:58:49] Environment details: ...
[6/22/2011, 11:58:49]CommandLine = E:\e37b899ee47800b4e62b990c\\Setup.exe /x86 /x64
[6/22/2011, 11:58:50]Loading localized engine data for language 1028 from E:\e37b899ee47800b4e62b990c\1028\LocalizedData.xml
[6/22/2011, 11:58:50] Entering Function: LocalizedData::CreateLocalizedData...
[6/22/2011, 11:58:50] exiting function/method
[6/22/2011, 11:58:50] succeeded
[6/22/2011, 11:58:50] Entering Function: EngineData::CreateEngineData...
[6/22/2011, 11:58:50]Current SetupVersion = 1.0
[6/22/2011, 11:58:50]SetupVersion specified in ParameterInfo.xml is '1.0'
[6/22/2011, 11:58:50]Adding Item type "Exe", local path SetupUtility.exe
[6/22/2011, 11:58:50]Adding Item type "MSI", local path RGB9RAST_x86.msi
[6/22/2011, 11:58:50]Adding Item type "MSI", local path RGB9RAST_x64.msi
[6/22/2011, 11:58:50]Adding Item type "ServiceControl", local path (not applicable)
[6/22/2011, 11:58:50]Adding Item type "File", local path Windows6.0-KB956250-v6001-x86.msu
[6/22/2011, 11:58:50]Adding Item type "Exe", local path Windows6.0-KB956250-v6001-x86.msu
[6/22/2011, 11:58:50]Adding Item type "File", local path Windows6.0-KB956250-v6001-x64.msu
[6/22/2011, 11:58:50]Adding Item type "Exe", local path Windows6.0-KB956250-v6001-x64.msu
[6/22/2011, 11:58:50]Adding Item type "File", local path Windows6.0-KB956250-v6001-ia64.msu
[6/22/2011, 11:58:50]Adding Item type "Exe", local path Windows6.0-KB956250-v6001-ia64.msu
[6/22/2011, 11:58:50]Adding Item type "File", local path Windows6.1-KB958488-v6001-x86.msu
[6/22/2011, 11:58:50]Adding Item type "Exe", local path Windows6.1-KB958488-v6001-x86.msu
[6/22/2011, 11:58:50]Adding Item type "File", local path Windows6.1-KB958488-v6001-x64.msu
[6/22/2011, 11:58:50]Adding Item type "Exe", local path Windows6.1-KB958488-v6001-x64.msu
[6/22/2011, 11:58:50]Adding Item type "File", local path Windows6.1-KB958488-v6001-ia64.msu
[6/22/2011, 11:58:50]Adding Item type "Exe", local path Windows6.1-KB958488-v6001-ia64.msu
[6/22/2011, 11:58:50]Adding Item type "File", local path netfx_Core.mzz
[6/22/2011, 11:58:50]Adding Item type "MSI", local path netfx_Core_x86.msi
[6/22/2011, 11:58:50]Adding Item type "MSI", local path netfx_Core_x64.msi
[6/22/2011, 11:58:50]Adding Item type "MSI", local path netfx_Core_ia64.msi
[6/22/2011, 11:58:50]Adding Item type "File", local path netfx_Extended.mzz
[6/22/2011, 11:58:51]Adding Item type "MSI", local path netfx_Extended_x86.msi
[6/22/2011, 11:58:51]Adding Item type "MSI", local path netfx_Extended_x64.msi
[6/22/2011, 11:58:51]Adding Item type "MSI", local path netfx_Extended_ia64.msi
[6/22/2011, 11:58:51]Adding Item type "Exe", local path dotNetFx40LP_Full_x86zh-Hant.exe
[6/22/2011, 11:58:51]Adding Item type "Exe", local path dotNetFx40LP_Full_x86_x64zh-Hant.exe
[6/22/2011, 11:58:51]Adding Item type "Exe", local path dotNetFx40LP_Full_x86_ia64zh-Hant.exe
[6/22/2011, 11:58:51]Adding Item type "Exe", local path SetupUtility.exe
[6/22/2011, 11:58:51]Adding Item type "ServiceControl", local path (not applicable)
[6/22/2011, 11:58:51]No ProcessBlock element
[6/22/2011, 11:58:51]No ServiceBlock element
[6/22/2011, 11:58:51]Disabled CommandLineSwitch added: createlayout
[6/22/2011, 11:58:51]Using Simultaneous Download and Install mechanism
[6/22/2011, 11:58:51] exiting function/method
[6/22/2011, 11:58:51] succeeded
[6/22/2011, 11:58:51] MaintenanceMode determination: evaluating EnterMaintenanceModeIf...
[6/22/2011, 11:58:51]evaluating EnterMaintenanceModeIf:
[6/22/2011, 11:58:51] Or: evaluating...
[6/22/2011, 11:58:51] And: evaluating...
[6/22/2011, 11:58:51] Equals: evaluating...
[6/22/2011, 11:58:51]TargetArchitecture is x86
[6/22/2011, 11:58:51] Equals evaluated to true
[6/22/2011, 11:58:51] Exists: evaluating...
[6/22/2011, 11:58:51]MsiGetProductInfo with product code {0A0CADCF-78DA-33C4-A350-CD51849B9702} found no matches
[6/22/2011, 11:58:51] Exists evaluated to false
[6/22/2011, 11:58:51] And evaluated to false
[6/22/2011, 11:58:51] Exists evaluated to true
[6/22/2011, 11:58:51] Equals evaluated to false
[6/22/2011, 11:58:51]MsiGetProductInfo with product code {8E34682C-8118-31F1-BC4C-98CD9675E1C2} found no matches
[6/22/2011, 11:58:51] Or evaluated to false
[6/22/2011, 11:58:51]MsiGetProductInfo with product code {394244F5-63DB-3B52-A1AB-3FF407A07E9B} found no matches
[6/22/2011, 11:58:51] MaintenanceMode determination evaluates to 'not in maintenance mode'
[6/22/2011, 11:58:51] Operation Type: ...
[6/22/2011, 11:58:51]Operation: Installing
[6/22/2011, 11:58:51] Package details: Microsoft .NET Framework 4 Setup...
[6/22/2011, 11:58:51]Package Name = Microsoft .NET Framework 4 Setup
[6/22/2011, 11:58:51]Package Version = 4.0.30319
[6/22/2011, 11:58:51] User Experience Data Collection Policy: ...
[6/22/2011, 11:58:51]User Experience Data Collection Policy: UserControlled
[6/22/2011, 11:58:51] Entering Function: UiDataT::CreateUiDataT...
[6/22/2011, 11:58:51]Loading file - E:\e37b899ee47800b4e62b990c\UiInfo.xml
[6/22/2011, 11:58:51]Add to schema collection schema file - E:\e37b899ee47800b4e62b990c\SetupUi.xsd
[6/22/2011, 11:58:51]Successfuly found file E:\e37b899ee47800b4e62b990c\1028\SetupResources.dll
[6/22/2011, 11:58:51]Successfuly found file E:\e37b899ee47800b4e62b990c\Strings.xml
[6/22/2011, 11:58:51] Global Block Checks: Checking for global blockers...
[6/22/2011, 11:58:51] BlockIf: Microsoft .NET Framework 4 已經包含在此作業系統中。您不需要安裝 .NET Framework 4 可轉散發套件。詳細資訊。...
[6/22/2011, 11:58:51]Microsoft .NET Framework 4 已經包含在此作業系統中。您不需要安裝 .NET Framework 4 可轉散發套件。詳細資訊。
[6/22/2011, 11:58:51]evaluating BlockIf:
[6/22/2011, 11:58:51]RegKeyValue: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\CBS does NOT exist.
[6/22/2011, 11:58:51]returning BoolWhenNonExistent's value: false
[6/22/2011, 11:58:51] BlockIf evaluated to false
[6/22/2011, 11:58:51] BlockIf: 已經將 .NET Framework 4 (含) 以上版本安裝在這部電腦上。...
[6/22/2011, 11:58:51]已經將 .NET Framework 4 (含) 以上版本安裝在這部電腦上。
[6/22/2011, 11:58:51] LessThanOrEqualTo: evaluating...
[6/22/2011, 11:58:51]RegKeyValue: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Version does NOT exist.
[6/22/2011, 11:58:52] LessThanOrEqualTo evaluated to false
[6/22/2011, 11:58:52] Equals: evaluating...
[6/22/2011, 11:58:52]Current Operation value is Installing
[6/22/2011, 11:58:52] Equals evaluated to true
[6/22/2011, 11:58:52] And evaluated to false
[6/22/2011, 11:58:52] BlockIf evaluated to false
[6/22/2011, 11:58:52] BlockIf: 安裝程式無法在相容性模式下執行。如需詳細資訊,請參閱讀我檔案。...
[6/22/2011, 11:58:52]安裝程式無法在相容性模式下執行。如需詳細資訊,請參閱讀我檔案。
[6/22/2011, 11:58:52]evaluating BlockIf:
[6/22/2011, 11:58:52] Exists: evaluating...
[6/22/2011, 11:58:52]Not In OS Compatability Mode
[6/22/2011, 11:58:52] Exists evaluated to false
[6/22/2011, 11:58:52] BlockIf: Microsoft .NET Framework 4 已經包含在此作業系統中,但是目前是關閉狀態。若要啟用 .NET Framework 4,請使用 [控制台] 中的 [開啟或關閉 Windows 功能]。詳細資訊。...
[6/22/2011, 11:58:52]Microsoft .NET Framework 4 已經包含在此作業系統中,但是目前是關閉狀態。若要啟用 .NET Framework 4,請使用 [控制台] 中的 [開啟或關閉 Windows 功能]。詳細資訊。
[6/22/2011, 11:58:52]RegKeyValue: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\OS Integration\v4 does NOT exist.
[6/22/2011, 11:58:52]returning BoolWhenNonExistent's value: false
[6/22/2011, 11:58:52] Equals evaluated to false
[6/22/2011, 11:58:52] BlockIf: 您沒有足夠權限為此電腦的所有使用者完成這項作業。請以系統管理員身分登入,然後再重新執行安裝程式。...
[6/22/2011, 11:58:52]您沒有足夠權限為此電腦的所有使用者完成這項作業。請以系統管理員身分登入,然後再重新執行安裝程式。
[6/22/2011, 11:58:52] Not: evaluating...
[6/22/2011, 11:58:52]IsAdministrator: IS a member of the Administrators group
[6/22/2011, 11:58:52] Exists evaluated to true
[6/22/2011, 11:58:52] Not evaluated to false
[6/22/2011, 11:58:52] BlockIf: .NET Framework 4 Client Profile 和 .NET Framework 4 Extended 必須分別移除。請使用 [控制台] 解除安裝這些程式。如需詳細資訊,請參閱讀我檔案。...
[6/22/2011, 11:58:52].NET Framework 4 Client Profile 和 .NET Framework 4 Extended 必須分別移除。請使用 [控制台] 解除安裝這些程式。如需詳細資訊,請參閱讀我檔案。
[6/22/2011, 11:58:52] BlockIf: 安裝程式無法繼續,因為前一個安裝要求您的電腦必須重新啟動。請重新啟動您的電腦,然後再重新執行安裝程式。...
[6/22/2011, 11:58:52]安裝程式無法繼續,因為前一個安裝要求您的電腦必須重新啟動。請重新啟動您的電腦,然後再重新執行安裝程式。
[6/22/2011, 11:58:52] And: evaluating...
[6/22/2011, 11:58:52]RebootPending: No reboot pending
[6/22/2011, 11:58:52] Or: evaluating...
[6/22/2011, 11:58:52] Or evaluated to true
[6/22/2011, 11:58:52] Or evaluated to false
[6/22/2011, 11:58:52] Not evaluated to true
[6/22/2011, 11:58:52] BlockIf: 無法使用這個安裝程式安裝 .NET Framework。如需詳細資訊,請參閱讀我檔案。...
[6/22/2011, 11:58:52]無法使用這個安裝程式安裝 .NET Framework。如需詳細資訊,請參閱讀我檔案。
[6/22/2011, 11:58:52] BlockIf: 這個安裝程式需要 IA64 或 x86 電腦,無法安裝在 x64 電腦上。如需詳細資訊,請參閱讀我檔案。...
[6/22/2011, 11:58:52]這個安裝程式需要 IA64 或 x86 電腦,無法安裝在 x64 電腦上。如需詳細資訊,請參閱讀我檔案。
[6/22/2011, 11:58:52]TargetArchitecture is x86
[6/22/2011, 11:58:52] BlockIf: 這個安裝程式需要 x64 或 x86 電腦,無法安裝在 IA64 電腦上。如需詳細資訊,請參閱讀我檔案。...
[6/22/2011, 11:58:52]這個安裝程式需要 x64 或 x86 電腦,無法安裝在 IA64 電腦上。如需詳細資訊,請參閱讀我檔案。
[6/22/2011, 11:58:52] BlockIf: 這個安裝程式需要 x86 電腦,無法安裝在 x64 或 IA64 電腦上。如需詳細資訊,請參閱讀我檔案。...
[6/22/2011, 11:58:52]這個安裝程式需要 x86 電腦,無法安裝在 x64 或 IA64 電腦上。如需詳細資訊,請參閱讀我檔案。
[6/22/2011, 11:58:52] BlockIf: 這個作業系統不支援 .NET Framework 4。如需詳細資訊,請參閱讀我檔案。...
[6/22/2011, 11:58:52]這個作業系統不支援 .NET Framework 4。如需詳細資訊,請參閱讀我檔案。
[6/22/2011, 11:58:52] GreaterThan: evaluating...
[6/22/2011, 11:58:52]TargetOS is 5.1.3
[6/22/2011, 11:58:52]all numeric characters - canonicalizing
[6/22/2011, 11:58:52] GreaterThan evaluated to false
[6/22/2011, 11:58:52]RegKeyValue: HKLM\SOFTWARE\Microsoft\Windows NT\CurrentVersion\InstallationType does NOT exist.
[6/22/2011, 11:58:53]returning BoolWhenNonExistent's value: false
[6/22/2011, 11:58:53] Equals evaluated to false
[6/22/2011, 11:58:53] And evaluated to false
[6/22/2011, 11:58:53] BlockIf evaluated to false
[6/22/2011, 11:58:53] BlockIf: 無法安裝 .NET Framework 4。電腦上的其他應用程式與這個程式不相容。如需詳細資訊,請參閱版本資訊。...
[6/22/2011, 11:58:53]無法安裝 .NET Framework 4。電腦上的其他應用程式與這個程式不相容。如需詳細資訊,請參閱版本資訊。
[6/22/2011, 11:58:53]evaluating BlockIf:
[6/22/2011, 11:58:53] And: evaluating...
[6/22/2011, 11:58:53] Equals: evaluating...
[6/22/2011, 11:58:53]Current Operation value is Installing
[6/22/2011, 11:58:53] Equals evaluated to true
[6/22/2011, 11:58:53] Or: evaluating...
[6/22/2011, 11:58:53]RegKeyValue: HKLM\SOFTWARE\Microsoft\.NETFramework\v4.0\Full\SBSDisabled\Install does NOT exist.
[6/22/2011, 11:58:53]RegKeyValue: HKLM\SOFTWARE\Microsoft\.NETFramework\v4.0\Core\SBSDisabled\Install does NOT exist.
[6/22/2011, 11:58:53] Or evaluated to false
[6/22/2011, 11:58:53] BlockIf: 執行安裝程式之前,必須先安裝 32 位元 Windows 影像處理元件 (WIC)。請造訪 Microsoft 下載中心,以便安裝 WIC,然後再重新執行安裝程式。...
[6/22/2011, 11:58:53]執行安裝程式之前,必須先安裝 32 位元 Windows 影像處理元件 (WIC)。請造訪 Microsoft 下載中心,以便安裝 WIC,然後再重新執行安裝程式。
[6/22/2011, 11:58:53] GreaterThanOrEqualTo: evaluating...
[6/22/2011, 11:58:53]TargetOS is 5.1.3
[6/22/2011, 11:58:53]all numeric characters - canonicalizing
[6/22/2011, 11:58:53] GreaterThanOrEqualTo evaluated to false
[6/22/2011, 11:58:53] LessThanOrEqualTo: evaluating...
[6/22/2011, 11:58:53] LessThanOrEqualTo evaluated to true
[6/22/2011, 11:58:53] GreaterThanOrEqualTo evaluated to true
[6/22/2011, 11:58:53] LessThanOrEqualTo evaluated to false
[6/22/2011, 11:58:53] GreaterThan: evaluating...
[6/22/2011, 11:58:53]FileVersion for C:\WINDOWS\system32\windowscodecs.dll is 6.0.6001.17009
[6/22/2011, 11:58:53] GreaterThan evaluated to false
[6/22/2011, 11:58:53]TargetArchitecture is x86
[6/22/2011, 11:58:53] BlockIf: 執行安裝程式之前,必須先安裝 64 位元 Windows 影像處理元件 (WIC)。請造訪 Microsoft 下載中心,以便安裝 WIC,然後再重新執行安裝程式。...
[6/22/2011, 11:58:53]執行安裝程式之前,必須先安裝 64 位元 Windows 影像處理元件 (WIC)。請造訪 Microsoft 下載中心,以便安裝 WIC,然後再重新執行安裝程式。
[6/22/2011, 11:58:53] Global Block Checks no blocking conditions found
[6/22/2011, 11:58:53]OpenFileMapping fails with last error: 6
[6/22/2011, 11:58:53]The handle to the section is Null
[6/22/2011, 11:58:53]Successfuly found file E:\e37b899ee47800b4e62b990c\1028\EULA.rtf
[6/22/2011, 11:58:53] Applicability for Installing: evaluating each item...
[6/22/2011, 11:58:53] Determining state: of E:\e37b899ee47800b4e62b990c\SetupUtility.exe...
[6/22/2011, 11:58:53]evaluating ApplicableIf:
[6/22/2011, 11:58:53] Determining state of E:\e37b899ee47800b4e62b990c\SetupUtility.exe - not applicable
[6/22/2011, 11:58:53] Determining state: of E:\e37b899ee47800b4e62b990c\RGB9RAST_x86.msi...
[6/22/2011, 11:58:53] And evaluated to true
[6/22/2011, 11:58:53]FileVersion for C:\WINDOWS\system32\rgb9rast_2.dll is 9.15.735.0
[6/22/2011, 11:58:53] Determining state of E:\e37b899ee47800b4e62b990c\RGB9RAST_x86.msi - not applicable
[6/22/2011, 11:58:53] Determining state: of E:\e37b899ee47800b4e62b990c\RGB9RAST_x64.msi...
[6/22/2011, 11:58:53] Determining state of E:\e37b899ee47800b4e62b990c\RGB9RAST_x64.msi - not applicable
[6/22/2011, 11:58:53] Determining state: of clr_optimization_v2.0.50727_32...
[6/22/2011, 11:58:53] Exists: evaluating...
[6/22/2011, 11:58:53]No FileVersion found for C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\mscorsvw.exe
[6/22/2011, 11:58:53] Exists evaluated to false
[6/22/2011, 11:58:53] Determining state of clr_optimization_v2.0.50727_32 - not applicable
[6/22/2011, 11:58:53] Determining state: of clr_optimization_v2.0.50727_64...
[6/22/2011, 11:58:53] Determining state of clr_optimization_v2.0.50727_64 - not applicable
[6/22/2011, 11:58:53] Determining state: of clr_optimization_v4.0.30319_32...
[6/22/2011, 11:58:53]No FileVersion found for C:\WINDOWS\Microsoft.NET\Framework\v4.0.30319\mscorsvw.exe
[6/22/2011, 11:58:53] Determining state of clr_optimization_v4.0.30319_32 - not applicable
[6/22/2011, 11:58:53] Determining state: of clr_optimization_v4.0.30319_64...
[6/22/2011, 11:58:53] Determining state of clr_optimization_v4.0.30319_64 - not applicable
[6/22/2011, 11:58:53] Determining state: of E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu...
[6/22/2011, 11:58:53] GreaterThan evaluated to true
[6/22/2011, 11:58:53] Not: evaluating...
[6/22/2011, 11:58:53] Not evaluated to true
[6/22/2011, 11:58:53]evaluating IsPresent:
[6/22/2011, 11:58:53]returning false
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu - available but not verified yet
[6/22/2011, 11:58:54] Determining state: of E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu...
[6/22/2011, 11:58:54]evaluating ApplicableIf:
[6/22/2011, 11:58:54] And: evaluating...
[6/22/2011, 11:58:54] LessThanOrEqualTo: evaluating...
[6/22/2011, 11:58:54]TargetOS is 5.1.3
[6/22/2011, 11:58:54]all numeric characters - canonicalizing
[6/22/2011, 11:58:54] LessThanOrEqualTo evaluated to false
[6/22/2011, 11:58:54] GreaterThan: evaluating...
[6/22/2011, 11:58:54] GreaterThan evaluated to true
[6/22/2011, 11:58:54] And evaluated to false
[6/22/2011, 11:58:54] Equals: evaluating...
[6/22/2011, 11:58:54]TargetArchitecture is x86
[6/22/2011, 11:58:54] Equals evaluated to true
[6/22/2011, 11:58:54] Not: evaluating...
[6/22/2011, 11:58:54] Exists: evaluating...
[6/22/2011, 11:58:54] Exists evaluated to false
[6/22/2011, 11:58:54] Not evaluated to true
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu - not applicable
[6/22/2011, 11:58:54] Determining state: of E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x64.msu...
[6/22/2011, 11:58:54] Equals evaluated to false
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x64.msu - not applicable
[6/22/2011, 11:58:54] Determining state: of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\Windows6.0-KB956250-v6001-ia64.msu...
[6/22/2011, 11:58:54] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\Windows6.0-KB956250-v6001-ia64.msu - not applicable
[6/22/2011, 11:58:54] Determining state: of E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu...
[6/22/2011, 11:58:54] And evaluated to true
[6/22/2011, 11:58:54]evaluating IsPresent:
[6/22/2011, 11:58:54]returning false
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu - available but not verified yet
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu - not applicable
[6/22/2011, 11:58:54] Determining state: of E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x64.msu...
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x64.msu - not applicable
[6/22/2011, 11:58:54] Determining state: of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\Windows6.1-KB958488-v6001-ia64.msu...
[6/22/2011, 11:58:54] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\Windows6.1-KB958488-v6001-ia64.msu - not applicable
[6/22/2011, 11:58:54] Determining state: of E:\e37b899ee47800b4e62b990c\SetupUtility.exe...
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\SetupUtility.exe - not applicable
[6/22/2011, 11:58:54] Determining state: of E:\e37b899ee47800b4e62b990c\netfx_Core.mzz...
[6/22/2011, 11:58:54] GreaterThanOrEqualTo: evaluating...
[6/22/2011, 11:58:54]RegKeyValue: HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client\Version does NOT exist.
[6/22/2011, 11:58:54]returning BoolWhenNonExistent's value: true
[6/22/2011, 11:58:54] GreaterThanOrEqualTo evaluated to true
[6/22/2011, 11:58:54] Or: evaluating...
[6/22/2011, 11:58:54]Current Operation value is Installing
[6/22/2011, 11:58:54] Or evaluated to true
[6/22/2011, 11:58:54]MsiGetProductInfo with product code {3C3901C5-3455-3E0A-A214-0B093A5070A6} found no matches
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Core.mzz - available but not verified yet
[6/22/2011, 11:58:54] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Core.mzz - not applicable
[6/22/2011, 11:58:55]returning BoolWhenNonExistent's value: true
[6/22/2011, 11:58:55] GreaterThanOrEqualTo evaluated to true
[6/22/2011, 11:58:55] And evaluated to false
[6/22/2011, 11:58:55] Or: evaluating...
[6/22/2011, 11:58:55] Equals: evaluating...
[6/22/2011, 11:58:55]Current Operation value is Installing
[6/22/2011, 11:58:55] Equals evaluated to true
[6/22/2011, 11:58:55] Not: evaluating...
[6/22/2011, 11:58:55] Exists: evaluating...
[6/22/2011, 11:58:55] Exists evaluated to false
[6/22/2011, 11:58:55] Not evaluated to true
[6/22/2011, 11:58:55] Or evaluated to true
[6/22/2011, 11:58:55] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Core.mzz - not applicable
[6/22/2011, 11:58:55] Determining state: of E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi...
[6/22/2011, 11:58:55]evaluating ApplicableIf:
[6/22/2011, 11:58:55] And: evaluating...
[6/22/2011, 11:58:55]TargetArchitecture is x86
[6/22/2011, 11:58:55] GreaterThanOrEqualTo: evaluating...
[6/22/2011, 11:58:55]RegKeyValue: HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client\Version does NOT exist.
[6/22/2011, 11:58:55] And evaluated to true
[6/22/2011, 11:58:55] Equals evaluated to false
[6/22/2011, 11:58:55]MsiGetProductInfo with product code {3C3901C5-3455-3E0A-A214-0B093A5070A6} found no matches
[6/22/2011, 11:58:55]evaluating IsPresent:
[6/22/2011, 11:58:55] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi - available but not verified yet
[6/22/2011, 11:58:55] Determining state: of E:\e37b899ee47800b4e62b990c\SetupUtility.exe...
[6/22/2011, 11:58:55] Determining state of E:\e37b899ee47800b4e62b990c\SetupUtility.exe - available but not verified yet
[6/22/2011, 11:58:55] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi - authored action for this item is NoOp
[6/22/2011, 11:58:55] Determining state: of E:\e37b899ee47800b4e62b990c\netfx_Core_x64.msi...
[6/22/2011, 11:58:55]MsiGetProductInfo with product code {F5B09CFD-F0B2-36AF-8DF4-1DF6B63FC7B4} found no matches
[6/22/2011, 11:58:55] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Core_x64.msi - not applicable
[6/22/2011, 11:58:55] Determining state: of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\netfx_Core_ia64.msi...
[6/22/2011, 11:58:55]MsiGetProductInfo with product code {8846F987-82AA-3412-BDD2-2EBBEE0F57AA} found no matches
[6/22/2011, 11:58:55] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\netfx_Core_ia64.msi - not applicable
[6/22/2011, 11:58:55] Determining state: of E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz...
[6/22/2011, 11:58:55]RegKeyValue: HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Version does NOT exist.
[6/22/2011, 11:58:55]MsiGetProductInfo with product code {0A0CADCF-78DA-33C4-A350-CD51849B9702} found no matches
[6/22/2011, 11:58:55] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz - available but not verified yet
[6/22/2011, 11:58:55] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz - not applicable
[6/22/2011, 11:58:56] Equals evaluated to true
[6/22/2011, 11:58:56] Not: evaluating...
[6/22/2011, 11:58:56] Exists: evaluating...
[6/22/2011, 11:58:56] Exists evaluated to false
[6/22/2011, 11:58:56] Not evaluated to true
[6/22/2011, 11:58:56] Or evaluated to true
[6/22/2011, 11:58:56] And evaluated to false
[6/22/2011, 11:58:56] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz - not applicable
[6/22/2011, 11:58:56] Determining state: of E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi...
[6/22/2011, 11:58:56]evaluating ApplicableIf:
[6/22/2011, 11:58:56] And: evaluating...
[6/22/2011, 11:58:56] Equals: evaluating...
[6/22/2011, 11:58:56]TargetArchitecture is x86
[6/22/2011, 11:58:56] GreaterThanOrEqualTo: evaluating...
[6/22/2011, 11:58:56]RegKeyValue: HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Version does NOT exist.
[6/22/2011, 11:58:56]returning BoolWhenNonExistent's value: true
[6/22/2011, 11:58:56] GreaterThanOrEqualTo evaluated to true
[6/22/2011, 11:58:56] And evaluated to true
[6/22/2011, 11:58:56] Or: evaluating...
[6/22/2011, 11:58:56]Current Operation value is Installing
[6/22/2011, 11:58:56] Equals evaluated to false
[6/22/2011, 11:58:56]MsiGetProductInfo with product code {0A0CADCF-78DA-33C4-A350-CD51849B9702} found no matches
[6/22/2011, 11:58:56]evaluating IsPresent:
[6/22/2011, 11:58:56] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi - available but not verified yet
[6/22/2011, 11:58:56] Determining state: of E:\e37b899ee47800b4e62b990c\SetupUtility.exe...
[6/22/2011, 11:58:56] Determining state of E:\e37b899ee47800b4e62b990c\SetupUtility.exe - available but not verified yet
[6/22/2011, 11:58:56] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi - authored action for this item is NoOp
[6/22/2011, 11:58:56] Determining state: of E:\e37b899ee47800b4e62b990c\netfx_Extended_x64.msi...
[6/22/2011, 11:58:56]MsiGetProductInfo with product code {8E34682C-8118-31F1-BC4C-98CD9675E1C2} found no matches
[6/22/2011, 11:58:56] Determining state of E:\e37b899ee47800b4e62b990c\netfx_Extended_x64.msi - not applicable
[6/22/2011, 11:58:56] Determining state: of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\netfx_Extended_ia64.msi...
[6/22/2011, 11:58:56]MsiGetProductInfo with product code {394244F5-63DB-3B52-A1AB-3FF407A07E9B} found no matches
[6/22/2011, 11:58:56] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\netfx_Extended_ia64.msi - not applicable
[6/22/2011, 11:58:57] GreaterThanOrEqualTo evaluated to true
[6/22/2011, 11:58:57] And evaluated to false
[6/22/2011, 11:58:57] Not: evaluating...
[6/22/2011, 11:58:57] Exists: evaluating...
[6/22/2011, 11:58:57] Exists evaluated to false
[6/22/2011, 11:58:57] Not evaluated to true
[6/22/2011, 11:58:57] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\netfx_Extended_ia64.msi - not applicable
[6/22/2011, 11:58:57] Determining state: of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\dotNetFx40LP_Full_x86zh-Hant.exe...
[6/22/2011, 11:58:57]evaluating ApplicableIf:
[6/22/2011, 11:58:57] And: evaluating...
[6/22/2011, 11:58:57] Equals: evaluating...
[6/22/2011, 11:58:57]Current Lcid value is 1028
[6/22/2011, 11:58:57]all numeric characters - canonicalizing
[6/22/2011, 11:58:57] Equals evaluated to false
[6/22/2011, 11:58:57]TargetArchitecture is x86
[6/22/2011, 11:58:57] Equals evaluated to true
[6/22/2011, 11:58:57] GreaterThanOrEqualTo: evaluating...
[6/22/2011, 11:58:57]RegKeyValue: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\1028\Version does NOT exist.
[6/22/2011, 11:58:57]returning BoolWhenNonExistent's value: true
[6/22/2011, 11:58:57] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\dotNetFx40LP_Full_x86zh-Hant.exe - not applicable
[6/22/2011, 11:58:57] Determining state: of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\dotNetFx40LP_Full_x86_x64zh-Hant.exe...
[6/22/2011, 11:58:57] Or: evaluating...
[6/22/2011, 11:58:57]No FileVersion found for E:\e37b899ee47800b4e62b990c\dotNetFx40LP_Full_x86_x64zh-Hant.exe
[6/22/2011, 11:58:57] Or evaluated to false
[6/22/2011, 11:58:57] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\dotNetFx40LP_Full_x86_x64zh-Hant.exe - not applicable
[6/22/2011, 11:58:57] Determining state: of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\dotNetFx40LP_Full_x86_ia64zh-Hant.exe...
[6/22/2011, 11:58:57]No FileVersion found for E:\e37b899ee47800b4e62b990c\dotNetFx40LP_Full_x86_ia64zh-Hant.exe
[6/22/2011, 11:58:57] Determining state of C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_4.0.30319\dotNetFx40LP_Full_x86_ia64zh-Hant.exe - not applicable
[6/22/2011, 11:58:57] Determining state: of E:\e37b899ee47800b4e62b990c\SetupUtility.exe...
[6/22/2011, 11:58:57] LessThanOrEqualTo: evaluating...
[6/22/2011, 11:58:57]TargetOS is 5.1.3
[6/22/2011, 11:58:57] LessThanOrEqualTo evaluated to false
[6/22/2011, 11:58:57] Determining state of E:\e37b899ee47800b4e62b990c\SetupUtility.exe - not applicable
[6/22/2011, 11:58:57]Path: C:\WINDOWS\Microsoft.NET\Framework\v4.0.20506 does NOT exist.
[6/22/2011, 11:58:57]Path: C:\WINDOWS\Microsoft.NET\Framework64\v4.0.20506 does NOT exist.
[6/22/2011, 11:58:57]Path: C:\WINDOWS\Microsoft.NET\Framework\v4.0.21006 does NOT exist.
[6/22/2011, 11:58:57]Path: C:\WINDOWS\Microsoft.NET\Framework64\v4.0.21006 does NOT exist.
[6/22/2011, 11:58:57]Path: C:\WINDOWS\Microsoft.NET\Framework\v4.0.30128 does NOT exist.
[6/22/2011, 11:58:57]Path: C:\WINDOWS\Microsoft.NET\Framework64\v4.0.30128 does NOT exist.
[6/22/2011, 11:58:57] Determining state: of MSIServer...
[6/22/2011, 11:58:57]returning true
[6/22/2011, 11:58:57]evaluating IsPresent:
[6/22/2011, 11:58:57]returning false
[6/22/2011, 11:58:57] Determining state of MSIServer - payload not required for this item to perform action.
[6/22/2011, 11:58:58] And: evaluating...
[6/22/2011, 11:58:58] GreaterThan: evaluating...
[6/22/2011, 11:58:58]TargetOS is 5.1.3
[6/22/2011, 11:58:58]all numeric characters - canonicalizing
[6/22/2011, 11:58:58] GreaterThan evaluated to true
[6/22/2011, 11:58:58] Equals: evaluating...
[6/22/2011, 11:58:58]TargetArchitecture is x86
[6/22/2011, 11:58:58] Equals evaluated to true
[6/22/2011, 11:58:58] And evaluated to true
[6/22/2011, 11:58:58] Not: evaluating...
[6/22/2011, 11:58:58] Exists: evaluating...
[6/22/2011, 11:58:58] Exists evaluated to false
[6/22/2011, 11:58:58] Not evaluated to true
[6/22/2011, 11:58:58]evaluating IsPresent:
[6/22/2011, 11:58:58]returning false
[6/22/2011, 11:58:58]evaluating ApplicableIf:
[6/22/2011, 11:58:58] GreaterThanOrEqualTo: evaluating...
[6/22/2011, 11:58:58]RegKeyValue: HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Client\Version does NOT exist.
[6/22/2011, 11:58:58]returning BoolWhenNonExistent's value: true
[6/22/2011, 11:58:58] GreaterThanOrEqualTo evaluated to true
[6/22/2011, 11:58:58] Or: evaluating...
[6/22/2011, 11:58:58]Current Operation value is Installing
[6/22/2011, 11:58:58] Or evaluated to true
[6/22/2011, 11:58:58]MsiGetProductInfo with product code {3C3901C5-3455-3E0A-A214-0B093A5070A6} found no matches
[6/22/2011, 11:58:58] Equals evaluated to false
[6/22/2011, 11:58:58] And evaluated to false
[6/22/2011, 11:58:58]RegKeyValue: HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Version does NOT exist.
[6/22/2011, 11:58:59]returning BoolWhenNonExistent's value: true
[6/22/2011, 11:58:59] GreaterThanOrEqualTo evaluated to true
[6/22/2011, 11:58:59] And evaluated to true
[6/22/2011, 11:58:59] Or: evaluating...
[6/22/2011, 11:58:59] Equals: evaluating...
[6/22/2011, 11:58:59]Current Operation value is Installing
[6/22/2011, 11:58:59] Equals evaluated to true
[6/22/2011, 11:58:59] Not: evaluating...
[6/22/2011, 11:58:59] Exists: evaluating...
[6/22/2011, 11:58:59] Exists evaluated to false
[6/22/2011, 11:58:59] Not evaluated to true
[6/22/2011, 11:58:59] Or evaluated to true
[6/22/2011, 11:58:59]evaluating IsPresent:
[6/22/2011, 11:58:59]MsiGetProductInfo with product code {0A0CADCF-78DA-33C4-A350-CD51849B9702} found no matches
[6/22/2011, 11:58:59]evaluating ApplicableIf:
[6/22/2011, 11:58:59] And: evaluating...
[6/22/2011, 11:58:59]TargetArchitecture is x86
[6/22/2011, 11:58:59] GreaterThanOrEqualTo: evaluating...
[6/22/2011, 11:58:59]RegKeyValue: HKLM\SOFTWARE\Microsoft\NET Framework Setup\NDP\v4\Full\Version does NOT exist.
[6/22/2011, 11:58:59] Equals evaluated to false
[6/22/2011, 11:58:59] And evaluated to false
[6/22/2011, 11:58:59] Applicability for Installing determination is complete
[6/22/2011, 11:58:59] Applicability Result Count: ...
[6/22/2011, 11:58:59]Number of applicable items: 7
[6/22/2011, 11:59:5] Action: System Requirement Checks...
[6/22/2011, 11:59:5] Action: Disk space check for items being downloaded...
[6/22/2011, 11:59:5]Drive:[C:\] Bytes Needed:[882106752] Bytes Available:[67896455168]
[6/22/2011, 11:59:5] Action complete
[6/22/2011, 11:59:5] Action: Enumerating incompatible processes...
[6/22/2011, 11:59:5]No Blocking Processes
[6/22/2011, 11:59:5] Action: Enumerating incompatible services...
[6/22/2011, 11:59:5]No Blocking Services
[6/22/2011, 11:59:5]Launching Download and Install operations simultaneously.
[6/22/2011, 11:59:5] Action: Downloading and/or Verifying Items...
[6/22/2011, 11:59:5]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu
[6/22/2011, 11:59:5] E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu: Verifying signature for Windows6.0-KB956250-v6001-x86.msu...
[6/22/2011, 11:59:6]E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu - Signature verified successfully for Windows6.0-KB956250-v6001-x86.msu
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu Signature verified successfully for Windows6.0-KB956250-v6001-x86.msu
[6/22/2011, 11:59:6]Signature verification succeeded for Windows6.0-KB956250-v6001-x86.msu
[6/22/2011, 11:59:6]File E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu, locked for install.
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\Windows6.0-KB956250-v6001-x86.msu Success
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu: Verifying signature for Windows6.1-KB958488-v6001-x86.msu...
[6/22/2011, 11:59:6]E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu - Signature verified successfully for Windows6.1-KB958488-v6001-x86.msu
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu Signature verified successfully for Windows6.1-KB958488-v6001-x86.msu
[6/22/2011, 11:59:6]Signature verification succeeded for Windows6.1-KB958488-v6001-x86.msu
[6/22/2011, 11:59:6]File E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu, locked for install.
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\Windows6.1-KB958488-v6001-x86.msu Success
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Core.mzz
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\netfx_Core.mzz: Verifying signature for netfx_Core.mzz...
[6/22/2011, 11:59:6]E:\e37b899ee47800b4e62b990c\netfx_Core.mzz - Signature verified successfully for netfx_Core.mzz
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\netfx_Core.mzz Signature verified successfully for netfx_Core.mzz
[6/22/2011, 11:59:6]Signature verification succeeded for netfx_Core.mzz
[6/22/2011, 11:59:6]File E:\e37b899ee47800b4e62b990c\netfx_Core.mzz, locked for install.
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Core.mzz Success
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi: Verifying signature for netfx_Core_x86.msi...
[6/22/2011, 11:59:6]E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi - Signature verified successfully for netfx_Core_x86.msi
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi Signature verified successfully for netfx_Core_x86.msi
[6/22/2011, 11:59:6]Signature verification succeeded for netfx_Core_x86.msi
[6/22/2011, 11:59:6]File E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi, locked for install.
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi Success
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\SetupUtility.exe
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\SetupUtility.exe: Verifying signature for SetupUtility.exe...
[6/22/2011, 11:59:6]E:\e37b899ee47800b4e62b990c\SetupUtility.exe - Signature verified successfully for SetupUtility.exe
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\SetupUtility.exe Signature verified successfully for SetupUtility.exe
[6/22/2011, 11:59:6]Signature verification succeeded for SetupUtility.exe
[6/22/2011, 11:59:6]File lock postponed for E:\e37b899ee47800b4e62b990c\SetupUtility.exe.
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\SetupUtility.exe Success
[6/22/2011, 11:59:6]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz
[6/22/2011, 11:59:6] E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz: Verifying signature for netfx_Extended.mzz...
[6/22/2011, 11:59:7]evaluating IsPresent:
[6/22/2011, 11:59:7] Exists: evaluating...
[6/22/2011, 11:59:7]MsiGetProductInfo with product code {3C3901C5-3455-3E0A-A214-0B093A5070A6} found no matches
[6/22/2011, 11:59:7] Exists evaluated to false
E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz - Signature verified successfully for netfx_Extended.mzz
[6/22/2011, 11:59:7] E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz Signature verified successfully for netfx_Extended.mzz
[6/22/2011, 11:59:7]Signature verification succeeded for netfx_Extended.mzz
[6/22/2011, 11:59:7]Starting install of item '.NET Framework 4 Client Profile' at tickCount = 3139796
[6/22/2011, 11:59:7]File E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz, locked for install.
[6/22/2011, 11:59:7]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Extended.mzz Success
[6/22/2011, 11:59:7]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi
[6/22/2011, 11:59:7] E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi: Verifying signature for netfx_Extended_x86.msi...
[6/22/2011, 11:59:7]E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi - Signature verified successfully for netfx_Extended_x86.msi
[6/22/2011, 11:59:7] E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi Signature verified successfully for netfx_Extended_x86.msi
[6/22/2011, 11:59:7]Signature verification succeeded for netfx_Extended_x86.msi
[6/22/2011, 11:59:7]File E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi, locked for install.
[6/22/2011, 11:59:7]Verifying Digital Signatures: E:\e37b899ee47800b4e62b990c\netfx_Extended_x86.msi Success
[6/22/2011, 11:59:7] Action complete
[6/22/2011, 11:59:7]WM_ACTIVATEAPP: Focus stealer's windows was NOT visible, taking back focus
[6/22/2011, 11:59:32]WM_ACTIVATEAPP: Focus stealer's windows WAS visible, NOT taking back focus
[6/22/2011, 11:59:53]WM_ACTIVATEAPP: Focus stealer's windows WAS visible, NOT taking back focus
[6/22/2011, 12:0:13]WM_ACTIVATEAPP: Focus stealer's windows WAS visible, NOT taking back focus
[6/22/2011, 12:1:8]evaluating IsPresent:
[6/22/2011, 12:1:8]returning false
[6/22/2011, 12:1:8] Exists: evaluating...
[6/22/2011, 12:1:8]MsiGetProductInfo with product code {3C3901C5-3455-3E0A-A214-0B093A5070A6} found no matches
[6/22/2011, 12:1:8] Exists evaluated to false
[6/22/2011, 11:59:5]calling PerformAction on an installing performer
[6/22/2011, 11:59:5] Action: Performing actions on all Items...
[6/22/2011, 11:59:5]Wait for Item (Windows6.0-KB956250-v6001-x86.msu) to be available
[6/22/2011, 11:59:6]Windows6.0-KB956250-v6001-x86.msu is now available to install
[6/22/2011, 11:59:6]Created new DoNothingPerformer for File item
[6/22/2011, 11:59:6]No CustomError defined for this item.
[6/22/2011, 11:59:6]Wait for Item (Windows6.1-KB958488-v6001-x86.msu) to be available
[6/22/2011, 11:59:6]Windows6.1-KB958488-v6001-x86.msu is now available to install
[6/22/2011, 11:59:7]Wait for Item (netfx_Core.mzz) to be available
[6/22/2011, 11:59:7]netfx_Core.mzz is now available to install
[6/22/2011, 11:59:7]Created new DoNothingPerformer for File item
[6/22/2011, 11:59:7]No CustomError defined for this item.
[6/22/2011, 11:59:7]Wait for Item (netfx_Core_x86.msi) to be available
[6/22/2011, 11:59:7]netfx_Core_x86.msi is now available to install
[6/22/2011, 11:59:7]Creating new Performer for MSI item
[6/22/2011, 11:59:7] Action: Performing Action on MSI at E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi...
[6/22/2011, 11:59:7]Log File C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_20110622_115851703-MSI_netfx_Core_x86.msi.txt does not yet exist but may do at Watson upload time
[6/22/2011, 11:59:7]Calling MsiInstallProduct(E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi, EXTUI=1
[6/22/2011, 11:59:7]MSI (E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi) Installation failed. Msi Log: Microsoft .NET Framework 4 Setup_20110622_115851703-MSI_netfx_Core_x86.msi.txt
[6/22/2011, 11:59:7]PerformOperation returned 1601 (translates to HRESULT = 0x80070641)
[6/22/2011, 11:59:7]Error 1601 is mapped to Custom Error: Retry
[6/22/2011, 11:59:7] E:\e37b899ee47800b4e62b990c\SetupUtility.exe: Verifying signature for SetupUtility.exe...
[6/22/2011, 11:59:7]E:\e37b899ee47800b4e62b990c\SetupUtility.exe - Signature verified successfully for SetupUtility.exe
[6/22/2011, 11:59:7] E:\e37b899ee47800b4e62b990c\SetupUtility.exe Signature verified successfully for SetupUtility.exe
[6/22/2011, 11:59:7]Signature verification succeeded for SetupUtility.exe
[6/22/2011, 11:59:7]File E:\e37b899ee47800b4e62b990c\SetupUtility.exe, is verified successfully.
[6/22/2011, 11:59:7]Created new ExePerformer for Exe item
[6/22/2011, 11:59:7] Action: Performing Action on Exe at E:\e37b899ee47800b4e62b990c\SetupUtility.exe...
[6/22/2011, 11:59:7]Launching CreateProcess with command line = SetupUtility.exe /wireregister
[6/22/2011, 12:1:7]Exe log file(s) :
[6/22/2011, 12:1:7]C:\DOCUME~1\XP\LOCALS~1\Temp\dd_SetupUtility.txt
[6/22/2011, 12:1:7]Log File C:\DOCUME~1\XP\LOCALS~1\Temp\dd_SetupUtility.txt exists and will be added to the Watson upload list
[6/22/2011, 12:1:7]Exe (E:\e37b899ee47800b4e62b990c\SetupUtility.exe) succeeded.
[6/22/2011, 12:1:7]Exe Log File: dd_SetupUtility.txt
[6/22/2011, 12:1:7] Action complete
[6/22/2011, 12:1:7]Helper item execution succeed.
[6/22/2011, 12:1:7]Delaying for Starting to delay
[6/22/2011, 12:1:8] Action: Performing Action on MSI at E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi...
[6/22/2011, 12:1:8]Log File C:\DOCUME~1\XP\LOCALS~1\Temp\Microsoft .NET Framework 4 Setup_20110622_115851703-MSI_netfx_Core_x86.msi.txt exists and will be added to the Watson upload list
[6/22/2011, 12:1:8]Calling MsiInstallProduct(E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi, EXTUI=1
[6/22/2011, 12:1:8]MSI (E:\e37b899ee47800b4e62b990c\netfx_Core_x86.msi) Installation failed. Msi Log: Microsoft .NET Framework 4 Setup_20110622_115851703-MSI_netfx_Core_x86.msi.txt
[6/22/2011, 12:1:8]PerformOperation returned 1601 (translates to HRESULT = 0x80070641)
[6/22/2011, 12:1:8] Action complete
[6/22/2011, 12:1:8]Error 1601 is mapped to Custom Error: Retry
[6/22/2011, 12:1:8]Retry 1 of 1 of custom error handling
[6/22/2011, 12:1:8]Retry count over existing limit, not going to retry again.
[6/22/2011, 12:1:8]OnFailureBehavior for this item is to Rollback.
[6/22/2011, 12:1:8] Action: Performing actions on all Items...
[6/22/2011, 12:1:8]Final Result: Installation failed with error code: (0x80070641), "無法存取 Windows Installer 服務。如果您在安全模式中執行,或 Windows Installer 未正確安裝,就可能發生。請連絡您的支援人員尋求協助。 " (Elapsed time: 0 00:02:17).
結果也不行....
ps 掃過毒了,沒有中毒
