最近因為硬碟實在放了太多東西~~~~
CDR已經罩不住了~~~昨天就跑去敗了一台DVD燒機回來備分~~~
想不到使用NERO在一開始的地方就會掛點跳出電源校準錯誤....
麻煩高手救命 ;cr; ~~~下面是問題的文件檔~~~
片子我是用中環低-R 8X
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:Program FilesAheadNeroWnaspi32.dll': Ver=2.0.1.74, size=164112 bytes, created 2004/10/26 下午 06:35:34
Nero Version: 6.6.0.16
Internal Version: 6, 6, 0, 16b
(Nero Express)
Recorder: <_NEC DVD_RW ND-3540A> Version: 1.01 - HA 1 TA 2 - 6.6.0.16
Adapter driver: <nvatabus> HA 1
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <PIONEER DVD-ROM DVD-116 >Version: 1.09 - HA 1 TA 3 - 6.6.0.16
=== Scsi-Device-Map ===
DiskPeripheral : NVIDIA STRIPE 149.04G nvraid Port 0 ID 1 DMA: Off
DiskPeripheral : IC35L040AVVA07-0 nvatabus Port 1 ID 0 DMA: Off
CdRomPeripheral : _NEC DVD_RW ND-3540A nvatabus Port 1 ID 2 DMA: Off
CdRomPeripheral : PIONEER DVD-ROM DVD-116 nvatabus Port 1 ID 3 DMA: Off
DiskPeripheral : WDC WD1600JD-00HBB0 nvatabus Port 2 ID 0 DMA: Off
CdRomPeripheral : AXV CD/DVD-ROM 2.2a a347scsi Port 4 ID 0 DMA: Off
CdRomPeripheral : Generic DVD-ROM 1.0 d347prt Port 5 ID 0 DMA: Off
=== CDRom-Device-Map ===
_NEC DVD_RW ND-3540A K: CDRom0
PIONEER DVD-ROM DVD-116 L: CDRom1
AXV CD/DVD-ROM M: CDRom2
Generic DVD-ROM N: CDRom3
AutoRun : 1
Excluded drive IDs:
WriteBufferSize: 83886080 (0) Byte
ShowDrvBufStat : 0
BUFE : 0
Physical memory : 1023MB (1048048kB)
Free physical memory: 625MB (640084kB)
Memory in use : 38 %
Uncached PFiles: 0x0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
16.9.2005
ISO編製
下午 07:23:49 #1 Text 0 File Isodoc.cpp, Line 6356
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet : TRUE
Allow pathdepth more than 8 directories : TRUE
Allow more than 255 characters in path : TRUE
Write ISO9660 ;1 file extensions : TRUE
下午 07:23:49 #2 Text 0 File Reader.cpp, Line 127
Reader running
下午 07:23:49 #3 Text 0 File Writer.cpp, Line 122
Writer _NEC DVD_RW ND-3540A running
下午 07:23:49 #4 ISO9660GEN -11 File geniso.cpp, Line 3309
First writeable address = 0 (0x00000000)
下午 07:23:49 #5 Text 0 File Burncd.cpp, Line 3233
Turn on Disc-At-Once, using DVD media
下午 07:23:50 #6 Text 0 File DlgWaitCD.cpp, Line 270
Last possible write address on media: 2298495 (510:46.45, 4489MB)
Last address to be written: 2298303 (510:44.03, 4488MB)
下午 07:23:50 #7 Text 0 File DlgWaitCD.cpp, Line 282
Write in overburning mode: NO (enabled: CD)
下午 07:23:50 #8 Text 0 File DlgWaitCD.cpp, Line 2483
Recorder: _NEC DVD_RW ND-3540A, Media type: DVD-R
Disc Manufacturer: TYG02 -
Disc Application Code: 64, Disc Physical Code: 193
下午 07:23:50 #9 Text 0 File DlgWaitCD.cpp, Line 448
>>> Protocol of DlgWaitCD activities: <<<
下午 07:23:50 #10 Text 0 File ThreadedTransferInterface.cpp, Line 838
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 ()
2 indices, index0 (150) not provided
original disc pos #0 + 2298304 (2298304) = #2298304/510:44.4
relocatable, disc pos for caching/writing not required/ required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2298304 blocks [_NEC DVD_RW ND-3540A]
下午 07:23:50 #11 Text 0 File ThreadedTransferInterface.cpp, Line 1051
Prepare recorder [_NEC DVD_RW ND-3540A] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4706926592, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_CtrlAdr_|_RecDep__________
0 | lead-in | 0 | 0x41 | 0x00
0 | 1 | 0 | 0x41 | 0x00
0 | 1 | 1 | 0x41 | 0x00
2298304 | lead-out | 1 | 0x41 | 0x00
下午 07:23:50 #12 Phase 24 File dlgbrnst.cpp, Line 1832
Caching of files started
下午 07:23:50 #13 Text 0 File Burncd.cpp, Line 4120
Cache writing successful.
下午 07:23:50 #14 Phase 25 File dlgbrnst.cpp, Line 1832
Caching of files completed
下午 07:23:50 #15 Phase 36 File dlgbrnst.cpp, Line 1832
Burn process started at 4x (5,540 KB/s)
下午 07:23:50 #16 Text 0 File ThreadedTransferInterface.cpp, Line 2654
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
下午 07:23:50 #17 Text 0 File DVDR.cpp, Line 2379
Recording mode: Sequential Recording Mode
下午 07:23:50 #18 Text 0 File Mmc.cpp, Line 21708
Set BUFE: Buffer underrun protection -> ON
下午 07:23:50 #19 Text 0 File DVDR.cpp, Line 2534
Start write address at LBA 0
DVD high compatibility mode: Yes
下午 07:23:50 #20 Text 0 File Cdrdrv.cpp, Line 8862
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-ROM (0), Part Version: 0.9x (0)
Disc Size: 120 mm, Maximum Rate: 2,52 Mbps (0 h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: ?
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 0 h (?)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h (LBN: FFFD0000 h, 4193920 MB)
Data in Burst Cutting Area (BCA) does not exist
Media Specific [16..63]:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
下午 07:23:51 #21 Text 0 File Cdrdrv.cpp, Line 1286
19:23:51.875 - _NEC DVD_RW ND-3540AH1 T2 : Queue again later
下午 07:24:19 #22 SCSI -1106 File Cdrdrv.cpp, Line 1434
SCSI Exec, HA 1, TA 2, LUN 0, buffer 0x0F640000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x03 (KEY_MEDIUM_ERROR)
Sense Code: 0x73
Sense Qual: 0x03
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x03 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x73 0x03
下午 07:24:19 #23 CDR -1106 File Writer.cpp, Line 311
Power calibration error
下午 07:24:19 #24 Text 0 File ThreadedTransfer.cpp, Line 228
all writers idle, stopping conversion
下午 07:24:19 #25 Text 0 File ThreadedTransfer.cpp, Line 222
conversion idle, stopping reader
下午 07:24:19 #26 Text 0 File DVDR.cpp, Line 2774
EndDAO: Last written address was -1
下午 07:24:19 #27 Phase 38 File dlgbrnst.cpp, Line 1832
Burn process failed at 4x (5,540 KB/s)
片子我是用中環低-R 8X
Windows XP 5.1
IA32
WinAspi: -
(Nero Express)
AutoRun : 1
Excluded drive IDs:
ShowDrvBufStat : 0
BUFE : 0
Use Inquiry : 1
16.9.2005
ISO編製
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Burning mode : DAO
Mode : 1
Joliet : TRUE
Reader running
DAO infos:
MCN: ""
Tracks 1 to 1:
DAO layout:
Sense Code: 0x73
Sense Qual: 0x03
