Originally posted by buniro@May 2 2005, 04:06 PM
不曉得Pro與Deluxe多了什麼弁鄔O?
The Pro version ($5) is also a Windows native program, and similar to the normal version. It is tuned, however, to the needs of users who diagnose the quality of ram often, or on multiple machines. It offers options like a "nice" mode which allows you to test RAM in the background, during normal use of the machine, as well as more detailed reporting of errors. It also does not pause every time an error is found, so it can be used to determine the overall reliability of ram that is prone to errors, rather than just as a tool that determines if there are any errors at all. Finally, it can be run without the "first time user" messages.
The Deluxe package ($12) includes the Windows native Pro version. It adds an embedded version of MemTest that runs from a bootable diskette. This version can be run on any PC with a floppy drive and does not require any sort of installation. Use it to check the RAM quality of any PC, whether it has Linux, Windows, or no OS at all. Plus, since it does not load an OS, it can directly access and test all of your RAM. This is a great disk for any computer technician to carry around. It also uses the speed that memory is checked as a basic benchmark of computer speed. This can be useful if you are testing different BIOS settings. Not only will MemTest tell you if you RAM is still stable, but it will also indicate if the tweaks you have made improve RAM performance.
