MEI's nWare Release 06.06 BETA 2 (x86) :
http://troglo.u-strasbg.fr/~3fmauricard/nware/nware_x86_06-06_beta2.exe
Infos :
See the ReadMe for the list of updates, but it use the latest drivers available. Don't forget to uninstall old drivers before update. (unless IDE RAID if you have your OS installed on a RAID Array)
This package should works from nForce 420-D to nForce590 SLI so anyone interesting in testing it is welcome. And as usual (I think) any feedbacks about compatibility will be appreciable. Simply use the dedicated forum section @ planetnvidia.com
Content of MEI’s nWare Release 06.06 (x86)
The package is made for Windows 2000/XP 32-bit OS and is International. It contains the following drivers:
Installer version 5.08
GART driver version 4.40
Memory controller driver version 4.40
SMBus driver version 4.56 (WHQL) with PCI-Express Root 4.45 (WHQL)
IDE SATA_IDE driver version 6.67
IDE Legacy PATARAID driver version 6.67
IDE SATARAID driver version 6.67
RAIDTOOL application version 6.69
Ethernet Pre-NRM driver version 4.71 for Windows XP / 4.40 for Windows 2000
Ethernet NRM driver version 60.15
Network management tools version 60.16
Audio driver version 4.65
Audio utility version 4.51
Display driver (ForceWare) version 91.28
About MEI's nWare
MEI's nWare is a set of drivers for the NVIDIA nForce series chipsets (i.e. the package should works from the first nForce 420-D to the latest nForce 590 SLI).
It was tested by on :
- NVIDIA nForce3 250Gb (MSI K8N Neo Platinum)
- NVIDIA nForce4 Ultra (MSI K8N Neo4 Platinum)
- NVIDIA GeForce 6150/nForce 430 (ASUS A8N-VM CSM)
But according to feedbacks it works also pretty well on nForce2.
Anyway, feedbacks will be much appreciated, just go at the dedicated forum section of Planet NVIDIA (www.planetnvidia.com).
History
* 06.06 *
- Updated: Installer from 5.01 to 5.08.
- Updated: SMBus driver from 4.52 to 4.56.
- Updated: IDE_SATA/Legacy PATARAID/SATARAID driver from 6.54 to 6.67.
- Updated: RAIDTOOL application from 6.54 to 6.69.
- Updated: Ethernet NRM driver from 53.08 to 60.15.
- Updated: Network management tools from 53.09 to 60.16.
- Updated: Audio driver from 4.64 to 4.65.
- Updated: Display driver from 84.66 to 91.28.
- Updated: Setup made with NSIS v2.17.
- Improved: New ReadMe file in Rich Text Format (RTF).
Infos :
About MEI's nWare
History
* 06.06 *
