網誌好讀版:http://downager.blogspot.tw/2013/06/lga711-xeon.html
前言
沒事不要亂看東西啊,不小心就跌入坑了
心血來潮想弄台雙路Xeon來玩,仔細評估價格和效能後決定採用LGA771作為主軸。
配備清單
Intel Xeon 5160 *2 (二手) $ 800
TYAN Tempest i5000VS (S5372) (庫存新品) $ 1500
Kingston DDR2 667 1G FB-Dimm *2 (二手) $ 600
LGA 771 原廠純銅CPU散熱器 *2 (二手) $ 500
保銳 戰斧 80+ 450W (全新) $ 1500
合計 $ 4900 (NTD)
配備介紹
Intel Xeon 5160(3GHz/4MB L2/1333MHz FSB)
這是Xeon(Woodcrest)採用Core 2架構(65nm)Server級雙核心處理器(2C/2T),
採用LGA 771(Socket J),全線只有Xeon 5160的TDP是80W,其餘皆為65W。
這張圖片可以看到,在左下角的部分有除錯代碼燈號,很貼心的設計
除錯燈旁邊的是Speaker,本來要去找來裝的,定睛一看才發現已經內建在板子上了阿
LGA 771 Socket *2
FBDIMM *6
雙Gigabit乙太網路卡
規格表:
Processor
‧ (2) LGA771 sockets
‧ Supports up to two Intel Xeon processors
5000/5100/5300 series; dual-core
‧ 1333/1066/667MHz FSB; VRD 11.0
Chipset
‧ Intel 5000V chipset
‧ Intel 6321ESB I/O Controller Hub
‧ SMSC SCH5017 Super I/O chip
Memory
‧ Dual memory channels
‧ (6) 240-pin DDR2 FBDIMM sockets
‧ Supports up to 24GB of ECC memory
‧ Supports FBDIMM 667/533MHz
Expansion Slots
‧ One 64/133 PCI-X slot in-lined with one (1)
inversed PCI-E x4 slot (routed to PCI-E x8 bus)
‧ One 32/33 PCI 2.3 slot
‧ One x8 PCI-E slot (with PCI-E x4 bus)
‧ One TYAN TARO SO-DIMM socket
Integrated I/O
‧ One floppy connector; one IDE connector
‧ Six (6) SATA ports support RAID 0, 1, 5, 10
‧ Four (4) USB 2.0 ports (two at rear, two via cable)
‧ Two (2) COM ports (one at rear, one via cable)
‧ Tyan 2 x 9 front-panel pin header
‧ Tyan 2 x 6 front-panel pin header for LAN/ID LED
‧ Two 25-pin connector for Tyan IPMI SMDC (opt.)
Back Panel I/O ports
‧ One 9-pin COM port
‧ One 15-pin VGA port
‧ Stacked PS/2 mouse & keyboard ports
‧ Following ports come with activity LED:
- Stacked two USB 2.0 & RJ45 10/100 ports
- Two RJ-45 10/100/1000 Base-T port
Integrated SATA Controller (ESB2)
‧ (1) Serial ATA Host controller embedded
‧ (6) SATA ports, RAID 0, 1, 5, 10 supported
(Window OS only)
‧ SATA activity LED connector
Integrated LAN Controllers
‧ Dual Gigabit MAC (ESB2 embedded) with
i82563EB dual-PHY
‧ Intel i82551QM fast ethernet LAN controller
- Operating at 32bit/33MHz interface
‧ Pin headers for front panel LAN LED
FB-Dimm
Fully Buffered DIMM(全緩存模組技術)串行內存技術
由INTEL公司研發,特點為採用已有的DDR2內存芯片,借助一個緩衝芯片將並行數據轉換
為串行數據流,並經由類似PCI Express的點對點高速串行總線將數據傳輸給CPU。若採用
DDR2-800顆粒,FB-DIMM的帶寬將提升到38.4GBps,而它的帶寬極限可突破57.6GBps。在
多通道設計上,FB-DIMM非常靈活,你可以使用單通道、雙通道、四通道或者是六通道。
(百度百科)
上機測試
先來張CPU-Z驗明正身
待機約1小時後的溫度
除了CPU以外其他最好都別摸,很燙很恐怖
再次驗身
AIDA64 Memtest
CINEBENCH R11.5
Nuclearus Multi Core
Fritz Chess Benchmark
總結:
單核效能被i3-3220菊爆,不過仗著實體四核心,全線程能贏個10%到30%沒問題的。
前言
沒事不要亂看東西啊,不小心就跌入坑了
配備清單
合計 $ 4900 (NTD)
配備介紹
LGA 771 Socket *2
FBDIMM *6
雙Gigabit乙太網路卡
規格表:
Processor
Chipset
Memory
Expansion Slots
Integrated I/O
(Window OS only)
i82563EB dual-PHY
FB-Dimm
(百度百科)
上機測試
先來張CPU-Z驗明正身
待機約1小時後的溫度
再次驗身
AIDA64 Memtest
CINEBENCH R11.5
總結:
