軟體簡介:
KMPlayer 是一款功能強大的播放軟體,其一些特殊功能是其他播放軟體沒有的,像是影片擷圖,將桌面背景設為播放影片,還有將目前播放的影片背景音樂擷取轉換成MP3格式的音樂檔等等,且其在播放影片上有許多視訊強化功能,可使其電腦的硬體設備發揮到最佳狀態!幾乎大部份的影音檔案都可以播放所以可以不用再加安裝其他播放軟體以節省電腦資源空間!
新版增加了新功能 :
1.可編輯段落,只撥放你喜歡的片段
2.可以改副檔名,在另存新檔時可以選擇新檔案格式(即類似轉檔能力主要可轉成*.avi檔)
Change Log:
Changes in KMPlayer 2.9.3.1212 (2007-01-21):
Fixed a serious bug of leaking memory with internal mkv parser.
Fixed a jerking problem of video when displaying overlay subtitles.
Fixed a quality issue of Chiptune (mod,xm) playback.
Fixed a problem of not showing embedded subtitles of ogm, mkv in seamless playback.
Fixed a problem of not showing subtitles on local network when playing a movie.
Fixed a bug in mov container, qt-ima4 audio lower than 44khz was not decoded correctly.
Adjusted the behavior of "Alt+Y" dialog box (Subtitle resync), to press "enter" will work as "apply" by default.
Fixed a bug of not updating key lists correctly on popup menu when switching key presets.
Fixed a bug in DVD drive/folder setup, it will be remembered correctly.
Fixed a bug of not correctly showing dvd title/chapter # on popup menu.
Fixed a bug of not displaying messages when pressing numpad del key (cycle video frame) in window mode.
Fixed a bug of not restoring a position of the title on skin when changing its window size.
Fixed a bug of not connecting internal aac parser with cyberlink audio decoder correctly.
Fixed a bug of launching an activemovie window when using ATI Mpeg video decoder for AVIO in overlay mixer.
Fixed a bug in exporting configurations to .reg file, some items was not correctly exported.
Fixed a bug of not displaying the title format of vqf.
Fixed a bug of not remembering correctly the selected album after restarting KMP when using hotkey (shift + #) for calling an album.
Fixed a bug of not parsing frame based .txt subtitles correctly.
Fixed a bug of not removing correctly configuration preset.
Fixed a bug of an a/v desync problem in some mov files.
Fixed a bug of not listing the file name of subtitles orderly on popup menu. (eg. a.srt, a.eng.srt, a.jpn.srt)
Fixed a bug in slideshow, aspect ratio will be kept as it is when switching to fullscreen by pressing "enter" in window mode.
Many bugfixes etc.
BDG Download
SN:KoFung@CBB
