小測一下便宜的K9NU-V + AM2 X2 3600+ (65nm 65W)
  • 主題發起人 主題發起人 SIMON
最近也有在組新電腦的考慮,不知道3600+和PD 915哪一個會是比較好的選擇說,傷腦筋中~~
3600+比較好...............
另外問一下,此顆3600+ x2 有內含AMD的Pacifica(就是Intel的VT)虛擬化技術嗎?謝謝
在AMD官網http://www.amd.com/us-en/Processors/ProductInformation/0,,30_118_8796,00.html
查到只有AMD Opteron™ Processors for Servers 支援 AMD Virtualization™ (AMD-V™) 技術!! 不知道跟pacifica一不一樣!?
Introducing AMD Virtualization™
Second-Generation AMD Opteron™ processors are designed to help end the “one server, one application” problem common in so many enterprises today. Most servers operate at less than 15 percent capacity, yet they still consume power and generate heat on a 24x7 basis. With native support for hardware-assisted AMD Virtualization™ (AMD-V™), Second-Generation AMD Opteron processors can help streamline the datacenter to achieve higher levels of efficiency and utilization.
Additionally, AMD’s integrated memory controller enhances virtualization and provides efficient virtual machine memory isolation for improved security and support of virtual users.
With AMD Virtualization, you can:
* Consolidate existing workloads: A single system can host disparate workloads along with their respective operating systems, middleware, and communications environments. Each workload continues to see a virtual environment that corresponds exactly to the physical environment of its earlier dedicated system, and while the virtual machines stand ready to respond to external requests they consume almost no machine resources or power in the absence of such requests.
* Facilitate the introduction of new applications: Instead of waiting for new hardware to begin development, IT can add new virtual machines to an existing physical server. Additionally, virtualization software environments can simplify the scheduling of planned hardware outages as well as the recovery from unplanned outages.
* Streamline software development: Developers must often adapt their code for a wide variety of operating system environments, and then test the code in those environments. Virtualization lets development organizations maintain a library of virtual machines corresponding to all the specific hardware and software environments on which their software runs.
* Ease migration to new operating systems: For client and server applications, virtualization supports multiple virtual machines, each running different versions of the same operating system. IT can then migrate specific applications at a pace convenient to IT and the end-user.
3600+ 雖然很超值...但是如果配原廠的散熱器超頻似乎有點壓不住
昨天跑雙sp2004雖然ok...今天安裝完CFX軟體去跑平行就掛了...反而opteron不會
雖然耗電量上opteron較大...但是超頻後的溫度控制似乎比3600好...
昨天出機試了一顆0705UPBW.同樣是65奈米.
512K快取.
但體質上跟0647MPM硬是差了一截.
試了一下.就不想試了.
512K快取.
但體質上跟0647MPM硬是差了一截.
試了一下.就不想試了.
阿~~是喔
越新的越不好超了阿?
請問ㄧ下您07年的U不加壓大約都在哪裡呢?
阿~~是喔
越新的越不好超了阿?
280*9左右.
再上就.......
MPM的序號是AMD自K7開始的變種.
序號是MPM的.好像都特別好超.
65nm 65W..和之前溫度..效能沒太大差別說...希望amd快快飛吧..加油..
感謝測試分享..;em25;
可以請SIMON兄測一下3DMark06嗎,看看X1950P在此平台可以跑幾分
PS.兄之前不是在用1950XT;x;
