[私空]Hyper PI 0.99b 跑馬的好工具最新版!
johnnyliu3377
此軟件基於Super PI 1.5製作,只要用來測試多核心CPU的計算能力,軟件界面很簡潔,選擇核心個數和測試大小後開始即可。主要是調用多個Super PI 1.5進行測試。例如雙核心調用兩個進程,最多支持32個。
載點:
http://homepage8.seed.net.tw/web@5/johnnyliu3377/hyper_vpi_0.99b.zip
ST-15K.3
我是恐龍..
收下
感謝強尼哥哥
周杰綸
是super-pi_mod-1.5的加強版嗎?還是進階版?
既然有新出的...那就先帶走了...
非常感激 多謝
h75658
感謝強尼大大分享!!
這個找了好久了呢!!
不知道要怎麼用耶...設定4核心按開始沒反應..
有人可以教我嗎??
狂少
Bulletproof Themer
johnnyliu3377
vista好像不能用?!!
國外網友說的:
put the SuperPi window on left upper side of the screen, select 32M test and that OK windows you need to move to upper right side of the screen and start it from there! it works :DThe Windows Vista incompatibility is related with the Audio service. You can temporarily stop/start this services using the following command-lines:
net stop "AudioSrv"
net start "AudioSrv"
Works fine as you can see in this thread: http://www.xtremesystems.org/forums/archive/index.php/t-54389.html
The snapshots are placed on snapshots folder.
Thank you!
狂爺不客氣;em25;
狂少
Bulletproof Themer
強尼爺,你有在xp上試用嗎?
我在xp上看不到計算過程,用16k試卻是一片空白溜...:)
