[font=標楷體]
【檔案名稱】:Hiren's BootCD Pro v1.5 史上最超強好用的開機光碟工具片最新版
【檔案大小】:214 MB
【檔案格式】:ISO
【語言種類】:英文
【官方網站】:http://www.hiren.info/
【檔案簡介】:
常用的 Windows、DOS 系統工具大全集,包括從磁碟分割、複製、防毒、資料救援、硬體檢測到硬碟維護、DOS 和 Windows 應用軟體方面的一張開機光碟,讓你一碟在手搞定各種電腦。
Hiren's Boot CD 是一套開機光碟,其包含各式各樣的診斷程式,例如:磁碟分割、系統效能測試、磁碟複製以及映像工具、資料救援工具、MBR 工具、BIOS 工具以及許多其他修復不同電腦問題的工具。它是可開機光碟; 因此即使在無法進入作業系統的情況下仍可使用。Hiren's Boot CD 具有軟體的詳盡清單。此光碟還擁有像 XPE 的功能可讓您在作業系統故障的情況下藉由此光碟開機模擬 XP 作業系統來拯救自己所需的重要資料。
>Hiren's BootCD - 合而為一的 DOS 開機光碟擁有底下這些工具程式: 磁碟分割工具、磁碟複製工具、防毒工具、復原修復工具、復原修復工具、測試工具硬碟工具等等...
Hiren's BootCD Pro V1.5 是從原來版本 v10 修改而來的,重新修改了結構以及選單,讓軟體能更方便以及有更好的描述,有些軟體也更新到最新版本,並且新增了許多其他有用的工具。
Hiren `s BootCD Pro 與 v10.0 版本的差異:
- Now the disc contains a new loader for DOS grub4dos (from CD version 1.3)
- Rewritten the structure and zapusknoe menu, with a more convenient avtoranom and Russian
descriptions of programs
- From a DOS-shell removed the program, no interest, obsolete or duplicate other.
- From under the WIN-shell removed outdated and of little programs, including antivirus MCafee (replaced by the Dr.Web CureIt and AVZ).
- Some programs are replaced by newer versions and Russified
- Also added a lot of other programs is useful, or substitute equivalent to more functional
- Uninstall Acronis, it makes no sense take the place of the old (eight) versions of these programs, because older version of Acronis True Image banal may not understand the images created by new versions Akronisa ...
- It is now easier to update files Dr.Web CureIt, Ad-Aware and AVZ. Differences Hiren's USB Pro + DOS version of Hiren's BootCD Pro
- Assembly based on the original assembly Hiren's BootCD ENG and Hiren's BootCD Pro
- Avtoran (shell programs) is replaced by a program Pstart 2.11, which you can edit (delete, add) lists of programs and descriptions.
- Changed the directory structure.
- Added the DOS shell, as in Hiren's BootCD Pro Differences Hiren's USB Pro version of Hiren's BootCD Pro
- Assembly based on the original assembly and Hiren's BootCD Hiren's BootCD Pro
- Removed everything related to the DOS-version of the assembly.
版本 1.5 中的變更
-Posted by Win-shell
- Kaspersky Virus Removal Tool 7.0.0.290
- Virtual Floppy Drive 2.1
- HxD 1.7.7.0
- Opened Files View 1.40
- Remove WGA 1.2
- EASEUS Partition Master Home Edition 4.0.1 Deleted by Win-shell
- Ad-Aware SE Personal 1.06 (base no longer updated)
- Hex Editor XVI32 (replaced HxD) Updated for DOS-shell
- Samsung The Drive Diagnostic Utility (ESTOOL) 3.00g
- IBM Hitachi Drive Fitness Test 4.15 Updated by Win-shell
- AVZ 4.32 (rus)
- Infra Recorder 0.50
- CCleaner 2.23.993
- Defraggler 1.13.155
- Recuva 1.29.429
- Wise Registry Cleaner Free 4.73.217
- CPU-Z 1.52
- SIW 2009-07-28
- PC Wizard 2009.1.90
- IMG Burn 2.5.0.0 (rus)
- CDBurnerXP 4.2.5.1490
- Updated base CureIt, AVZ, KAV, Spybot Search & Destroy
http://www.badongo.com/file/17382956
[/font]
【檔案大小】:214 MB
【檔案格式】:ISO
【語言種類】:英文
【檔案簡介】:
版本 1.5 中的變更
- HxD 1.7.7.0
- Remove WGA 1.2
- AVZ 4.32 (rus)
- CCleaner 2.23.993
- Recuva 1.29.429
- CPU-Z 1.52
- SIW 2009-07-28
[/font]
