GSKILL FX 新品新鲜测.........
haohao0208
看看本尊~~~~
Introduction :
G.Skill introduces their new DDR400 2-2-2-5 1GB matched pair and 512MB single module as FX series, with Samsung TCCD extreme memory chips, that are compatible with both Intel and AMD platforms.
After launching several high frequency series, G.Skill announces the new FX series which guarantees to DDR400 2-2-2-5 specification.
As some platforms cannot overclock so easily, DDR400 optimization is the best options for these users. G.Skill FX series match this kind of requirement perfectly.
Specification :
* Package : 1024MB kit (2x512MB) dual channel pack
* IC Spec : Samsung TCCD
* CAS Latency : 2-2-2-5 (PC3200)
* Test Voltage : 2.7~2.8 V
* PCB Board : 6 Layers PCB
* Speed : DDR 400 MHz (PC3200)
* Type : 184-pin DDR SDRAM
* Error Checking : Non-ECC
* Registered/Unbuffered : Unbuffered
* Quality Control : Comprehensive rigorously tested in pair at dual channel environment
* Warranty : Lifetime
Let's see some pics:
直接回来来了个3001T
这样的体制算好吗???
好U好RAM ;face0;
不過32MPI跑的有點慢
coolaler 說:
好U好RAM ;face0;
不過32MPI跑的有點慢
給你一個LIVE ;em03;
原廠風扇跑3G
G.SKILL FX DDR600 3-4-8-4@2.7V
haohao0208
还要等c大给我指点,哈哈,好u也是c大精选的
