FX-6300, little beast for OC time
FlanK3r
OK, tehre is it a few...Today I tested IMC and looks strong as hell. No way comparison Bulldozer and Vishera in this. I used max 1.35V for CPUNB clocks. CPU voltage was dropping in load, in idle was higher.
There is some stability test for 30 minutes (for me OK and for reviews)
4965 MHz is not bad with this voltage :)...In idle you can see 1.465V, but in load it was only 1.44V! The main problem are temps, this chip could easy 5 GHz stable with better cooling and a bit higher voltage.
I booted at 2900 MHz CPUNB to windows, I was suprised. After I tried superpi1M, superpi 32M was not stable for it :-(
And AIDA memory bandwith :)
Cinebench R11.5 is able up to 2840 MHz! Validation time:
http://valid.canardpc.com/show_oc.php?id=2761978
I think, this will be good candidate for LN2, low VID, good OC in normal condition, stronger IMC. Later Il try DRAM clocks at max.
cenxuebin
:MMM: Wow NB Frequency
FlanK3r
yes, Vishera looks strong :)
FlanK3r
WHat I got is this:
I tested older Crosshair V Formula, I believe with Formula-Z could be a bit better. I used this limits: CPUNB voltage 1.355 V, DRAM voltage 1.7 V, VDDA 2.6V only. Switching at DRAM phase x2. CPU clocks was not priority.
Superpi 16M up to 2580 MHz
Superpi 1M 2600 MHz, 2608 MHz I got bluescreen :):
AIDA 64 for fun :)
Timings was most of time 11-13-14-...-300-2T, DRAm GSkill TridentX 2666 11-13-13-2t for Ivy Bridge
