foobar2000 v0.9.5 beta 1
aomori
AMD台灣策進總會
0.9.5
New Default User Interface
o
Allows embedding of Album List and other components in the main window
o
Quick setup dialog on first startup allowing easy UI customization
o
Theme import/export support for transferring appearance-related settings easily
o
Built-in playlist view supports columns and grouping
o
New Playlist Search dialog
o
Embedded album art support
o
New built-in spectrum visualisation
New Album List component
o
Updates automatically with Media Library content changes (“Refresh” command no longer needed)
o
Embeddable in the main window
o
Supports direct creation of autoplaylists from Album List tree branches
Properties dialog improvements
o
New commands: “Format from Other Fields”, “Capitalize”, “Clean Up”
o
Improved “Automatically Fill Values” functionality
o
Improved Windows Clipboard interaction - now you can use copy/paste to transfer values between fields or between different sets of tracks
Converter component improvements
o
Replaced “show output directory when done” functionality with a new dialog showing a list of created tracks
o
Built-in support for writing AU/SND and AIFF files
o
Updated FLAC support - FLAC encoding now requires FLAC encoder 1.2.0 or newer
o
Improved handling of hung command-line encoder processes
Audio format decoding updates
o
Updated libFLAC to 1.2.0
o
Rewritten support for AU/SND and AIFF audio formats
New “File Operations” component, for moving, copying and deleting audio files
Old Masstagger component no longer included with the installer (available for download separately)
Windows XP or newer is now required
H
hidemygod
訪客
大大改進預設介面的樣式!
雖然我還是用改的XDD
很棒的程式唷
hyde211
感謝分享
azurenook
木村迷
感謝分享;cheer2;
checkpoint
很棒的音樂播放軟體!感恩!
接下來要學學怎麼修改面板!
Rhea
飛河幽夢
lgs0809
大海管理 員
感謝分享,雖然已經從它處更新。^_^
brianoa
不知道用起來有沒有什麼差
感謝分享喔
