WINDOWS 仿 MAC 軟體
v3.5更新內容
CHANGELOG PRE-3.5 (30.2mb)
- changed UberIcon tray icon
- updated iTunes Multi-Plugin from 2.2 to 2.3
- added mplayerc.exe (Media Player Classic in K-Lite Mega Codec pack)
- added msascui.exe (Windows Defender)
- added check/alert if System Restore is not running, giving user chance to enable it before proceeding
- changed Rebuild Icon Cache tool
- fixed System Notifiaction sound pointing to wrong file path
- fixed default XP screensaver not uninstalling properly
- fixed Copy File dialog appearing when uninstalling Office files
- updated and cleaned up iColorFolder OS X skin
- updated iColorFolder to 1.4.1 (Helped KemenAran change the context menu color circles to the official OS X ones)
- fixed problems with System Files Updater and Microsoft Office files
- added My Documents\My Shapes icon for Visio
- added My Documents\My Web Sites icon for FrontPage
- fixed misc. installer/uninstaller code
- fixed icon cache not being rebuilt on restart occassionaly
- fixed boot.ini read-only attribute after modification
- fixed Command Console filename/path completion to default Tab key
- fixed coloring of FrontPage icon
- added bluetooth system tray icons
- fixed the move taskbar tool so that it will not quit if the taskbar has not been moved properly
- added googledesktopresources_en.dll (Google Desktop Search tray icon - English only)
- added winssro.dll (Windows OneCare tray icon)
- added images in System Restore Wizard
- removed CD access cursor in user32.dll (causes blue screens on certain machines)
- fixed Security Center images not applying on Chinese Simplified systems
- fixed telnet.exe and dfsg.dll icons not applying on Chinese Simplified systems
- fixed System Files Updater autorun entry in registry not being removed on uninstall
- added dsquery.dll
- fixed ObjectDock installing if ObjectDock Pro is installed
- fixed black around certain icons in RK Launcher
- "Remove Uninstaller and Backup Files" option must now be uninstalled seperately from other options to avoid problems
- added widescreen boot screen
- added comctl32.dll file in system32 folder
- added paintdotnet.exe (Paint.NET)
- added iColorFolder link to Start Menu -> FlyakiteOSX -> Software
- added directx.cpl
- fixed pink around corners of installer splash screen
- added winbrand.dll
- added yahoowidgetengine.exe
- Outlook.exe is skipped if Windows OneCare is installed (OneCare causes problems with a modified Outlook.exe)
- fixed Logon Screen font issues for certain international languages
- added UberIcon 1.0.2 software
- fixed ntoskrnl.exe & logonui.exe not getting restored when using "BATCH RestoreFlyakiteOSX.txt"
- fixed RK Launcher settings being overwritten if already installed
- fixed Mail icon in Control Panel not getting modified on non-english 1033 systems
- added avsmcpa.cpl (McAffee Anti-Virus)
- added neroburnright.cpl (Nero 7 BurnRight)
- added lclock.cpl (Lclock)
- added audiohqu.cpl (SoundBlaster Audio HQ)
- added bdeadmin.cpl (BDE Admin Tools)
- updated SearchSpy from 1.0 to 1.1 (fixes all the error message popups and more)
- fixed all Current User Settings tool bugs
- fixed xpsp2res.dll and setupapi.dll icons not applying on Chinese Simplified systems
- added option to choose between 48x48 and 128x128 max icon size in system files
- fixed bug when Uninstaller was run after installing FlyakiteOSX (but before restarting), the system would still be in OS X style
- fixed btrez.dll
- fixed issues with installation pausing at "Preparing Update..." on very, very rare instances
- fixed System Files Updater option in Current User Settings tool
- fixed boot screen issues
- fixed system sounds quality
下載點:
http://rohizzle121.be/a/FlyakiteOSX v3.5.exe
http://pwnzc.com/files/flyakite/FlyakiteOSX v3.5.exe
v3.5更新內容
- added dsquery.dll
- added directx.cpl
- fixed btrez.dll
下載點:
