FAH 硬體及客戶端綜合討論 (part 2)
  • 主題發起人 主題發起人 monkp
恭喜OverFold隊友bigadv bonus開張。
是啊!我也是今早起來才發現到那股氣勢....
都是多得各位的資訊更新才能有此成績,
你的問題我也曾遇過,始終只有remove work再create過或是只有等......
真好, 小弟還在用 6C/12T 4G + I7 920 4G 再跑 windows smp
已做完 4 個 A3 WU, 理想狀況再做完 六個 A3 WU, 就可以開張 轉跑 VMWARE,
可是剛剛看了一下 1% 需要的時間 for Project 6012
再 smp 8 跟 smp 12 好像沒差多少 都是接近 3 分鐘,
蠻怪的? 難道 server 會記住我曾經用過 -smp 8 去連他嗎?
oegg隊友第11個A3 WU已順利取得bonus,得到3756分。
等這個跑完 再來裝 VMWARE
請教一下 VMWARE Player 3.0 是不是只能 8 core?
太多 Thread 反而無法全用上... XD
Yes...
難怪之前看到的6C/12T bigadv記錄,都是在native Linux下運算而得。
手動改CFG檔也不行?VM真的未Support到~
相信要待下一版本的VM推出Patch才能完全發揮得到12T的威力。
那麼跑一個BIGADV再行多一組Windows -smp 4,假如擔心會
互搶資源可能要好像測SP2004般用TaskMan分配各Core運行吧!
用VirtualBox呢?
應該就沒有8T的限制了。
Virtualbox可支援到32T,但之前在bigadv VM運算方面穩定度有待改善,所以先前會建議
使用支援至8T的VMPlayer 3.0.0。個人使用VMPlayer 3.0.0至今bigadv未發生過系統異常,
穩定度極佳。
Virtualbox最近的版本(v3.0.10之後)可能有所改善,有興趣的隊友可試試以下URL
所提供的Virtualbox image:
http://www.linuxforge.net/docs/crunching/fah-virtualbox.php
以下為該image的說明:
Introduction
Virtualbox has support for up to 32-core processors. I have had good success so far running 8-core folding with the Folding@home CPU SMP client and the 1920 pt Core A2 work units. Virtualbox v3.0.10 has additional SMP fixes that makes bigadv folding a possibility also. With past versions, Virtualbox would crash with one of several errors messages when trying to fold with bigadv. There is still an issue with bigadv folding where the CPU usage will fluctuate between 70 and 100% while using 8-cores. I do not have much runtime with the bigadv folding in Virtualbox so there may still be other stability issues.
The Windows Virtualbox folding is experimental and stability is unknown since there are different possible processor configurations. Make sure your system, CPU, and memory are completely stable and all temps under load are normal before trying out folding in Virtualbox.
