FAH 硬體及客戶端綜合討論 (part 1)
  • 主題發起人 主題發起人 monkp
弄不出來~
請問GTX280也是v1.07版核心??  ;cheer2;
我把舊核心重新命名
然後把新核心放進去
然後重開fah
Log裡顯示的使用核心就從1.06變成1.07了
我只換了Application Data\Folding@home-gpu裡的Core_11.exe而已
一次跑兩個應該就是換兩個~
我把舊核心重新命名
然後把新核心放進去
然後重開fah
一次跑兩個應該就是換兩個~
3Q3Q~~
所給的1.07好像是1.06. 都是1.73MB 1,822,720Bit:PPP:
OS VISTA32
另―台主力 VISTA64 PC、弄了24小時、始終2個GPU設定不起來、;smash...
In Windows Vista:
Executable: C:\Program Files (x86)\Folding@home\Folding@home-gpu\Folding@home.exe"
Data Files: C:\Users\<your_windows_username>\AppData\Roaming\Folding@home-gpu\"
以上是 Vista 安裝的路徑, 大大在試試看囉 :)
VISTA SPECIFIC:
You still need to have a second monitor attached to enable the second card
64 bit OS with 8xxx/9xxx card:
Detailed instructions for Windows XP and Windows Vista.
1. Unpack the self extractor exe
2. Copy in the modified inf file
3. "Have-Disk method" - Start -> Control Panel -> System -> Device Manager -> right click on display adaptor -> properties -> Update Driver.
Point the updater at the folder where you extracted the driver.
4. Reboot
5. Check the new driver version is installed. Start -> Control Panel -> Nvidia Control Panel -> System Information -> ForceWare version.
官方 FAQ
Kev兄
;sorry; ;sorry;
解決1.07的問題。
GTX280記的要去最新的驅動177.41,有改善CUDA的效能,個人感覺啦。
不知怎麼的,算到一半就停止,接著上傳了。
不知是不是換了1.07版核心的關係
以下是LOG訊息:
[11:39:20] Completed 88%
[11:43:41] Completed 89%
[11:48:06] Completed 90%
[11:52:29] Completed 91%
[11:56:52] Completed 92%
[12:01:06] Gromacs cannot continue further.
[12:01:06] Going to send back what have done.
[12:01:07] logfile size: 118321 info=118321 bed=23 hdr=1
[12:01:07] - Writing 118857 bytes of core data to disk...
[12:01:07] Done: 118345 -> 12088 (compressed to 10.2 percent)
[12:01:07] ... Done.
[12:01:07]
[12:01:07] Folding@home Core Shutdown: UNSTABLE_MACHINE
[12:01:11] CoreStatus = 7A (122)
[12:01:11] Sending work to server
[12:01:11] - Read packet limit of 540015616... Set to 524286976.
[12:01:11] + Attempting to send results
[12:01:13] + Results successfully sent
[12:01:13] Thank you for your contribution to Folding@Home.
[12:01:17] + Closed connections
[12:01:17] + Paused after finishing unit
(我的設定是算完暫停,所以最後一行是正常的)
跑到92%就不能繼續了,獎勵也跟著縮水了480-->446
不知是甚麼原因呢?從Log似乎看不出來問題在哪
