EVGA更新BIOS問題
jay00316
到官方網站下載了E658_A72然後也將bios還原到預設了
將E658_A72幾壓縮用NERO製作開機DVD BOOT 但是當讀到光碟內容再跑當中突然停在DR DOS A:->..這段
然後又在試著用隨身碟格式化開機製作HPUSBFW DOS開機 將bios更新檔跟AWDFLASH丟置隨身碟內 將bios >boot > Hard DISK Driver設為usb開機但也卡在c:/....(就是跑出win 98之後跑出C..
第1次更新bios請大大們指導我的盲點......
jay00316
救命...簡單跟我說一下BIOS更新流程也可以......................
jay00316
註明EVGA P55 FTW200主機板~..
bhg0523
你可以看一下你下載頁面的上方喔
會發現User Manual...
會發現你的方法錯很大...
jay00316
請問是EVGA官方網站 BIOS下載介面上方嗎? 沒找到...
bhg0523
那你是怎麼下載的阿?
在Download的下面不就是安裝方法嗎?...
The following drivers/files are available for your hardware and operating system combination.
Note: If you are having difficulties downloading the driver file, please make sure you completely disable any third party download managers.
Bios Version : A72
BIOS Date : 09/29/2010
Bios File : Download
Notes :
The following has been updated in A72:
Now CPU multiplier can be adjusted with Turbo offset
INSTRUCTIONS: BIOS updating can be accomplished VIA the below method:
Download the following .zip file: E659_A72.zip
Go into the folder where you unzipped this package and run the appropriate batch file.
For Windows XP, Vista or 7 32Bit: AFUWIN32.BAT
For Windows XP, Vista or 7 64Bit: AFUWIN64.BAT
Press Y in CAPITAL LETTERS.
DO NOT TURN OFF POWER OR RESET DURING THE FLASH PROCESS
After the flashing is finished, shut down the computer. Then power on again and go into BIOS, Load Defaults, Save and Exit
Warning:
**Do not restart or interrupt your PC while the flash is ongoing
**Do not Flash BIOS on overclocked settings
**It is always recommended to power-down after flash
lung6412h
爬文一下記得好像跟之前舊款msi主機板的更新方式一樣,找一下應該有的.
cyzcamera
咕咕忠
現在下載回來解壓縮後,都有可以直接在WINDOWS下可以刷BIOS的工具。
若您的DOS真的刷不成功就試試在WIN下刷吧!
我的P55 FTW,刷了N次了,DOS及WIN都可以!
asetadam
嗨~嗨
windows下刷就好了
刷之前記得先將BIOS SWITCH調到你要的區段
簡單又方便
jay00316
恩 我再試試看...
