EpoX has launched the EP-AF570+ Ultra, a mainboard uniquely tailored to meet the needs of enthusiast and die-hard performance users. Carrying on the success of 9NPA+ Ultra, engineers at EPOX once again present a no-frills mainboard purely focused on engineering and ease of use. Unlike other high-end mainboards squeezed with add-on chips to improve on selling point, the EP-AF570+ Ultra is designed with layout, tuning features and quality component as top priority.
NVIDIA nForce® 570 Ultra™ Chipset
Based on NVIDIA nForce4 ® Ultra ™ media and communications processors (MCPs), EP-AF570+ Ultra features AMD Socket AM2 processor support through a 1GHz HyperTansport link. It supports 4 DDR2 SDRAM DIMM slots in dual-channel mode and ready for the ultra high speed DDR2-800 up to 16GB system memory. With 6 SATA ports enabled through the SATA 3Gb/s RAID controller, EP-AF570+ Ultra satisfies favorable high bandwidth data transfer and the all-important data security. Armored with 10 ports of USB2.0 expansion for I/O peripheral will never be a problem.
Dual Gigabit LAN, High Definition Audio
The EP-AF570+ Ultra is equipped with Dual Realtek RTL8111B Gigabit Ethernet controller allowing the PC to serve as a network gateway to balance data transfer efficiency making it suitable for streaming multimedia from the internet and across the users network. The onboard Realtek ALC883 Azalia HD Audio Codec brings high-quality 8-channel HD audio at 192KHz/24-bit and multi-streaming technology that simultaneously sends different audio streams to different destinations. You can now talk to your partners on the headphone while playing a multi-channel network games. These perfect combination makes the EP-AF570+ Ultra an exceptional home server platform for ultimate gaming and entertainment.
Perfect for Heavy Duty coolers
EP-AF570+ Ultra is tailored to accomodate high end CPU coolers and watercooling blocks that typically take up real estate on a mainboard. For example, the chipset is well placed away from the CPU area allowing more for heavy duty CPU coolers. CPU socket components have been carefully selected for this same purpose. In addition, memory slots are placed at an optimized distance from CPU, making space for high end memory modules with thicker heatplate and display features.
Technicalities
For more stable performance and higher overclocking margin EP-AF570+ Ultra uses 4-phase CPU power design coupled with solid state silicon capacitors. All this ensures the CPU gets enough uninterrupted juice in extreme overclocking situations. As for the chipset, the chipset is cooled with a large heatsink mounted with high quality two-ball-bearing active cooling fan. This simple design ensures low noise operating environment with longer lifetime. Under normal circumstances the large heatsink guarantees the chipset is sufficiently cooled should the chipset fan fails. For overclocking, the EP-AF570+ Ultra features frequency adjustment for CPU, memory and PCI-E. Most importantly, there is a bevy of voltage adjustment features for chipset, CPU and DIMM (including over 3.0V for memory voltage!) and HTT bus.
EPoX's classic LED Post Port has proven as a valuable trouble shooting tool and has earned its place on this board as well. The improved "EZ Button" with LED, helps power users to be able to switch on the board without any other cables and directly power on the board by button.
Reincarnate your PC with “Ghost BIOS”
EPoX has invented and developed the EP1308 SUPER I/O chip to support a powerful BIOS recovery function called Ghost BIOS. With Ghost BIOS user don't need to send their mainboards back for repair due to corrupted BIOS. By simply following the steps in the "Thunder Flash" utility their BIOS will be recovered and flashed to the latest BIOS version. So, how good is Ghost BIOS? Ghost BIOS is so powerful that even if the onboard BIOS chip is removed, the PC can still boot!
Finally EP-AF570+ Ultra bundles "Thunder Probe", a hardware monitoring utility software that helps users to see voltage, temperature and speeds for a variety of hardware; "Smart Fan", an intelligent fan speed controller to reduce fan noise;
With focus on engineering instead of laden with add-on components that compromise performance, the EP-AF570+ Ultra breaks tradition to offer a refreshing yet powerful platform to power users and enthusiast.
Key Specifications
● Supports Socket-AM2 based AMD Sempron/Athlon-64/ Athlon-64 FX/Athlon X2.
● Supports PCI-E x16 in single VGA mode.
● Supports DDR2 800 up to 16GB.
● Supports 6 SATA II, up to 3.0Gb/sec.
● Supports 7.1 channel high definition audio.
● Supports Dual GbE LAN.
● Supports up to 450MHz CPU frequency in BIOS adjustable in 1MHz increments.
● New generation of hardware monitoring software "Thunder Probe" and "Ghost Monitor".
● Thunder Flash software to rescue corrupted BIOS, BIOS auto update and personal start up screen.
● EPoX debug LED "POST PORT" and "LEDION".
● EPoX on board direct power on/off switch "EZ Button"
可惜台灣應該看不到了
Technicalities
Key Specifications
可惜台灣應該看不到了
