好亮的底座!!!EnzoTech-Ultra-X CPU散熱器
官網
Compatible with all single and dual-core CPUs for Intel® Socket 775 and AMD™ Sockets K8/AM2/754/939/940
The base of the Heat Sink is machined to 0.0003 per inch run-out, which optimizes surface contact and maximizes thermal conductivity performance
Four 8 mm heat pipes guarantee the CPU will always run smooth and at optimum efficiency
The large 120 mm fan provides extreme volume of airflow which will keep your Northbridge chipset cool at the same time
Artic Silver®5 Thermal Grease and Adjustable fan speed control included
Dimension (L x W x H) 148x148x118mm
Total Weight 835g
Fan
Delta Fan AFB1212H-F00
Dimension (L x W x H) 120x120x25.4mm
Speed 1200~2500 RPM
Noise 24.5~38.5 dB-A
Air Flow 35.8~82.67 CFM
Voltage 12VDC . 0.35A
Connector Molex 2695- 3 Wire
Bearing Type 2-Ball
Heatsink
Base Forge C1100 Copper Base , Mirror Polished
Material Aluminum Fins
Heatpipes 4 Piece of 8∅ Pipes
Thermal Grease Arctic Silver® 5
連顯存散熱片也是亮晶晶
Ultra-X彩盒
本體
附送的散熱膏鏡射在拋光的銅底座
特殊的黑色管狀散熱鰭片鎖在銅底座上
大面積的散熱片
將熱導管帶來的廢熱傳導,再由風扇帶動氣流吹走廢熱
配件
官網
Total Weight 835g
Fan
Speed 1200~2500 RPM
Bearing Type 2-Ball
Heatsink
連顯存散熱片也是亮晶晶
Ultra-X彩盒
本體
附送的散熱膏鏡射在拋光的銅底座
特殊的黑色管狀散熱鰭片鎖在銅底座上
大面積的散熱片
配件
