【軟體名稱】:Easy RM RMVB to DVD Burner 1.7.1~免安裝
【軟體語言】:繁體中文
【軟體分類】:燒錄程式
【軟體格式】:RAR
【檔案大小】:4.52 MB
【放置空間】:depositfiles/ mediafire
【解壓密碼】:no
它可以幫助你轉換RM等影片格式到標准的DVD格式,並集結燒錄成 DVD影片。它支援市面上大部分流通的幾種影片格式,例如 Divx、Xvid、AVI和其它格式,它也可以產生DVD映像文件,儲存到硬碟,或是從硬碟直接把DVD映像文件燒錄到DVD光碟上。支援NTSC和 PAL兩種電視制式,也支援4:3和16:9顯示畫面。
Key Features of Easy RM RMVB to DVD Burner
# Creates DVD from RM RMVB files and burn to blank DVD disc
# Generate DVD image and save to hard disk
# Burn hard disk DVD image to blank DVD disc
# Super fast conversion speed provided as it full supports Intel Pentium D Dual-Core Processor and AMD Athlon? 64 X 2 Dual-Core Processor which ensures full use of your CPU
# Merge up to 3 hours of multiple movies or episodic files to one DVD
# Multithreading and batch conversion are supported and the more files you convert the faster Easy RM RMVB to DVD Burner works than other DVD creators
# So easy to use that only ONE click is enough to burn a DVD after you loaded the video files
# Supports device types include DVD-R/ DVD+R/ DVD-RW/ DVD+RW
# Support NTSC and PAL
# Support 4:3 and 16:9 aspect ratio
# Add letterbox to keep the original aspect ratio
# All encoders/codec are built-in and any supported conversion can be done once you downloading the software
# Make excellent output quality
# Neat User Interface,very easy to use,without any complicated parameter settings
# No ASPI drivers needed
# Lifetime FREE Technical Support and FREE upgrade
V.1.7.1: (09/26/2010)
fix some micro bugs.
最強的免費空間下載器~免安裝 JDownloader 0.9.580~免安裝 JDownloader 0.9.580~免安裝 確保下載的軟體能正常使用,請使用 WinRAR 3.93 - Final 正體中文版 (32 位元) WinRAR 3.93 - Final 正體中文版 (32 位元) |
