【軟體名稱】:Easy DVD Creator v2.1.0 免安裝
【軟體語言】:繁體中文
【軟體分類】:影音剪輯/ 燒錄程式
【軟體格式】:RAR
【檔案大小】:7.32 MB
【放置空間】:RapidShare/ depositfiles
【解壓密碼】:no
Easy DVD Creator,可將AVI/DIVX/XVID/DIV, MPEG/MPG/DAT, WMV/ASF/ASX, RM/RMVB, MOV/QT, 3GP/3G2, MP4/M4V, 和FLV等視頻檔案轉換為DVD。它也可以產生DVD映像檔案,儲存到硬碟,或是從硬碟直接把DVD映像檔案燒錄到DVD光碟上。支援NTSC和PAL兩種電視制式,也支援4:3和16:9顯示畫面。
Key Features of Easy DVD Creator
* Creates DVD from AVI/DIVX/XVID/DIV, MPEG/MPG/DAT, WMV/ASF/ASX, RM/RMVB, MOV/QT, 3GP/3G2, MP4/M4V, FLV, and TOD files and burn to blank DVD disc.
* Generate DVD image and save to hard disk
* Burn hard disk DVD image to blank DVD disc
* Super fast conversion speed provided as it full supports Intel Pentium D Dual-Core Processor and AMD Athlon? 64 X 2 Dual-Core Processor which ensures full use of your CPU
* Merge up to 3 hours of multiple movies or episodic files to one DVD
* Multithreading and batch conversion are supported and the more files you convert the faster Easy DVD Creator works than other DVD creators
* So easy to use that only ONE click is enough to burn a DVD after you loaded the video files
* Supports device types include DVD-R/ DVD+R/ DVD-RW/ DVD+RW
* Support NTSC and PAL
* Support 4:3 and 16:9 aspect ratio
* Add letterbox to keep the original aspect ratio
* All encoders/codec are built-in and any supported conversion can be done once you downloading the software
* Make excellent output quality
* Neat User Interface,very easy to use,without any complicated parameter settings
* No ASPI drivers needed
* Lifetime FREE Technical Support and FREE upgrade
*******本帖可能隱藏重要的內容需要回覆才可以完整瀏覽*******
最強的免費空間下載器 JDownloader 0.9.579 免安裝
確保下載的軟體能正常使用,請使用WinRAR 3.93 Final 版本解壓
WinRAR 3.93 - Final 正體中文版 (32 位元)
