E2140空冷超頻3.6G SP2004能跑多久?
嘉義敗家宅男
測試結果揭曉ˇ ˇ
唉…居然沒過兩小時,殘念阿
;smash;
koichi70
spaces.msn.com
hahahhah 本來以為會跑出天長地久的時間 哈哈哈哈 ~~ 真的是殘念了 >< ahhaha
S20814
雖然沒有過2Hr,但是對一般人來說已經夠了啦,這顆CPU真是變態:)
sai_luffy_5
設2個BLEND的情形下...2小時爆炸...
如果設1個LARGE + 1個BLEND...應該跑不過10分鐘吧...
E2140...跑450X8這樣的極限數字...感覺上太嚴苛了@@!
不過如果跑400X8很夠一般人用了...
不曉得是不是我的E2140體質比較差...跑400X8...要穩跑ORTHOS過24小時要加壓到1.57V..
我是跑到41小時手動停止...(有抓圖...但是我不曉得怎麼貼 @@")
嘉義敗家宅男
不信邪一.一!!
再重測1個LARGE + 1個BLEND
電壓1.488v
1小時過關:eek:
可能是我的運氣比較好吧;em25;
E2140 電壓1.488v OC 3.6G 記憶體1G 800 X4 OC 1200Mhz
呵呵...我的運氣還不錯1.488v超頻3.6G目前測過1小時,
下回再測試燒機時間看能過12小時嗎>"<
;ranger;
zoreaabbcc
嘴砲無敵~!!
1.488 = =||| 天氣冷也不能這樣啦 XD~~~再不行去衝一箱乾冰跟他拼了ˋˊ
嘉義敗家宅男
主機板BIOS 0907
以下為我的BIOS設定
如下:
Asus X38 Series BIOS Settings from OPB
CPU Feature:
Ai Overclock Tuner [Mauna]
CPU Ratio Control [Manual]
Ratio CMOS Setting: [AUTO]
FSB Frequency [450]
FSB Strap to North Bridge [AUTO]
PCIE Frequency [100]
DRAM Frequency [1199]
DRAM Command Rate [2T]
DRAM Timing Control [Manual]
CAS# Latency [5]
RAS# to CAS Delay [5]
RAS# Precharge [5]
RAS# Active Time [15]
RAS# To Ras# Delay [AUTO]
Row Refresh Cycle Time [AUTO]
Write Recovery Time [AUTO]
Read To Precharge Time [AUTO]
Read To Write Delay(S/D) [AUTO]
Write To Read Delay(S) [AUTO]
Write To Read Delay(D) [AUTO]
Read To Read Delay(S) [AUTO]
Read To Read Delay(D) [AUTO]
Write To Write Delay(S) [AUTO]
Write To Write Delay(D) [AUTO]
DRAM Static Read Control [AUTO] [不懂該項目,目前設置系統預設值AUTO]
Ai Clock Twister [Strong]
Transaction Booster [Enabled]
Boost Level [0]
Voltage Settings:
CPU Voltage [1.56250v]
CPU PLL Voltage [Auto]
North Bridge Voltage [1.61v]
DRAM Voltage [AUTO]
FSB Termination Voltage [AUTO]
South Bridge Voltage [AUTO]
Loadline Calibration [AUTO] [這個應該是防掉壓吧?我設開啟,SP2004無法順利跑,
所以設AUTO,可能電壓需要調整後,開啟才能順利跑SP2004]
CPU GTL Reference [AUTO]
North Bridge GTL Reference [AUTO]
DDR2 Channel A REF Voltage [AUTO]
DDR2 Channel B REF Voltage [AUTO]
DDR2 Controller REF Voltage [AUTO] [這項目我設DDR2_REF時,
DRMA電壓調2.2v,還是跑2.3v一樣多1v,所以設AUTO] [/COLOR]
SB 1.5V Voltage [Auto]
NB LED Selection [NB Volt] 系統預設
SB LED Selection [SB Volt] 系統預設
CPU LED [CPU Volt] 系統預設
Voltiminder LED [Enabled] 系統預設
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Configuration 頁面設定
CPU Ratio Control [Auto] 系統預設
C1E Support [Enabled] 設置Enabled,因為日常使用即為OC 3.6G,
沒滿載時讓BIOS降2個倍頻低溫跑2.7G
CPU TM function: [Enabled] [不懂該項目,目前設置系統預設值Enabled]
Vanderpool Technology [Enabled] [不懂該項目,目前設置系統預設值Enabled]
Execute Disable Bit [Enabled] [不懂該項目,目前設置系統預設值Enabled]
Max CPUID Value Limit [Disabled] [不懂該項目,目前設置系統預設值Disabled]
Intel(R) SpeedStep(tm) Tech. [Enabled] [不懂該項目,目前設置系統預設值Enabled]
嘉義敗家宅男
Thermalright Ultra-120 eXtrem 掛雙風扇好像散熱沒比較好一.一
目前還少一顆2000轉風扇,目前使用前方1500轉風扇,後方2000轉風扇,可能是前方風扇轉速跟不上後方風扇,所以溫度不降反生吧!!!
等再買一顆2000轉風扇再來測試單風扇與雙風扇散熱溫度^^
簡測了一下Thermalright Ultra-120 eXtrem 單風扇
3.6G 跑雙核版-SP2004 開啟1個LARGE + 1個BLEND
的溫度表現
發現跟雙風扇溫度差不到5度一.一
或許是因為雙風扇,前1500轉後2000轉的關係
兩個轉速差了500轉,影嚮了雙風扇的效能。
但噪音值差很多>"<
還是單風扇安靜一點;tongue;
t00late
我不是當英雄的料
雙風扇的最佳化 不是就是要2個風扇轉速和風量略有不同嗎?
Asurada
哇..E2140也可以這麼猛阿~
小弟的跑個3.2G就已經很勉強了說
真是好U
