DFI LP UT P35-T2R求診掛號單
狂少
Bulletproof Themer
希望大家能善用這個表格,
所以當你有問題要求救時也比較方便:)
有些是既定建議值留起來也不錯:)
代碼:
[B]
CPU Feature
- Thermal Management Control: Disabled
- PPM(EIST) Mode: Disabled
- Limit CPUID MaxVal: Disabled
- CIE Function: Disabled
- Execute Disable Bit: Disabled
- Virtualization Technology: Disabled
- Core Multi-Processing: Enabled
Exist Setup Shutdown: Mode 2
CLOCK VC0 divider: AUTO
CPU Clock Ratio Unlock: Enabled
CPU Clock Ratio:
- Target CPU Clock:
CPU Clock:
Boot Up Clock:
DRAM Speed:
- Target DRAM Speed:
PCIE Clock: 100mhz
Voltage Settings
CPU VID Control:
CPU VID Special Add:
DRAM Voltage Control:
SB 1.05V Voltage:
SB Core/CPU PLL Voltage:
NB Core Voltage:
CPU VTT Voltage:
Vcore Droop Control: Enabled
Clockgen Voltage Control: 3.45v
GTL+ Buffers Strength: Strong
Host Slew Rate: Weak
GTL REF Voltage Control: Disable
x CPU GTL1/3 REF Volt: 110
x CPU GTL 0/2 REF Volt: 110
x North Bridge GTL REF Volt: 110
DRAM Timing
- Enhance Data transmitting: AUTO
- Enhance Addressing: AUTO
- Channel 1 CLK fine delay: AUTO
- Channel 2 CLK fine delay: AUTO
CAS Latency Time (tCL):
RAS# to CAS# Delay (tRCD):
RAS# Precharge (tRP):
Precharge Delay (tRAS):
All Precharge to Act: AUTO
REF to ACT Delay (tRFC): AUTO
Performance Level: AUTO
MCH ODT Latency: AUTO
Write to PRE Delay (tWR): AUTO
Rank Write to Read (tWTR): AUTO
ACT to ACT Delay (tRRD): AUTO
Read to Write Delay (tRDWR): 8
Ranks Write to Write (tWRWR): 6
Ranks Read to Read (tRDRD): 6
Ranks Write to Read (tWRRD): 5
Read CAS# Precharge (tRTP): AUTO
ALL PRE to Refresh: AUTO
PCIE Slot Config: 1X 1X
CPU Spread Spectrum: Disabled
PCIE Spread Spectrum: Disabled
SATA Spread Spectrum: Disabled
[/b]
s837047
感謝狂爺整體詳細的設定表 ... :MMM:
但這張主板現在光華缺貨中 ... ;face12;
zoreaabbcc
嘴砲無敵~!!
考慮入手P35中,狂大真早阿 小弟還在ZZZZ 先收下哩
albertyin
nobody
晚一點來去試看看;face0;
dabenla
滄者小P
謝謝狂爺的求診單!
相信有了這些設定值...
原來有些看不懂的設定要這樣設定喔!^^
實在太感激了^^
讓我省掉看不懂嘗試的時間和風險!呵呵...
現在Y和P賣場都有賣唷!大概9580....含運
Andre
造訪網站
謝謝狂爺的求診單!
相信有了這些設定值...
原來有些看不懂的設定要這樣設定喔!^^
實在太感激了^^
pchome 還可以刷卡含稅比他便宜 , 拒買吧 , 合理價錢不會超過9千 , 都是黑心代理商賺去了
狂少
Bulletproof Themer
抓到了
還不俯首認罪....
龜毛王;smash;
albertyin
nobody
還好小弟入手價含運剛好9000;em25;
