Cheetah DVD Burner v2.46_可以燒錄雙面光碟的軟體
le2712
【軟體名稱】:Cheetah DVD Burner v2.46
【軟體語言】:英文
【軟體分類】:燒錄程式
【軟體格式】:RAR
【檔案大小】:19.1 MB
【放置空間】:depositfiles/ RapidShare
【解壓密碼】:no
【軟體介紹】:
一款DVD光碟燒錄軟體,可以燒錄雙面DVD+R、DVD+RW、DVD-R、DVD-RW、DVD-RAM、CD-R和CD-RW。也可以燒錄 CD/DVD 啟動光碟,ISO 映像檔案,以及由Mp3、MP2、WMA、WAV、OGG檔案燒錄成音頻CD。此外還包括音樂CD的提取工具和很多其他的有用的工具。
Features:
- Video DVD Mastering - The Cheetah DVD Burner passes the Video DVD Verifier tests and Mastering Applications like the most known Philips Video DVD Verifier.
- Bootable CD/DVD - Create Bootable CD/DVD from .img files
- Supports high burning speeds - Supports use of high write speeds - Designed for high data rates
- Buffer Underrun Protection - Support for hardware buffer underrun protection systems, like BURNproof, JustLink, Power-Burn, SafeBurn, SeamlessLink etc
- ISO Multi-Session - Burn Multi-Session Data CD/DVD with all types of media.
- Disc Finalization - No further writing is possible after the disc is burned.
- Auto Verify Data - Performs a binary compare with the source files.
- Joliet - Burn Joliet directories with 64 char file names
Project Types:
- UDF Video DVD - Burn a Video DVD from an ISO, Bin/Cue, or Video_TS folder
- DVD+R Dual Layer - Backup your data on 8.5 GB DVD+R discs
- Data DVD - Backup your data on DVD+R, DVD+RW, DVD+R, DVD-RW, DVD-R, DVD-RAM
- Data CD - Burn a standard CD or CD-RW
- Audio CD - Creates Red Book compatible audio CDs from mp3, mp2, avi, ogg, wma, and wav files
- Audio CD Ripper - Extract audio from an Audio CD
- Copy a Data CD - Copy a data disc
- Copy an Audio CD - Copy an audio disc
- Burn ISO file - Burn ISO image files
- Bin/Cue file Burner - Burn Bin/Cue image files
- Create ISO file - Builds ISO Images from selected files for burning at a later date
- Convert Audio - Convert audio files from mp3, mp2, avi, ogg, wma, and wav files
- Erase Disc - Erase CD/DVD discs
System Requirements - Windows 98/Me/NT/2000/XP/Vista
Homepage - http://www.cheetahburner.com
確保下載的軟體能正常使用,請使用
WinRAR 3.91 Final 版本解壓
