因為之前發佈的cFosSpeed 4.20 Build 1389,
安裝完後流量圖,不會正常作用;sorry;
在此發佈修正的版本:)
使用過ADSL的人,多多少少都會感覺如果網路有在上傳東西的話,
下載速度就會變慢,其實這就是所謂的「集縮比」。
如果你常用eDonkey、eMule或BT這類P2P軟體的話,
這種情況特別明顯。如果我們把軟體的上傳速度調低,
我們的下載速度就會受影響,但如果不限上傳的話,
不但我們在開啟網頁速度會變慢,相對的,我們的網路其實也沒有物盡其用。
cFosSpeed它所採用的技術,可以讓我們同時上傳及下載其之間的影響降到最低,
讓你不但不用調整或限制上傳速度,就可以擁有一定水準的下載速度,另一方面,
更讓你的網路頻寬充份的被利用。
使用教學
Download
Windows Vista/2003 Server/XP/2000
您的回覆,是我發文的動力;shakehand
Download
Windows Vista/2003 Server/XP x64 Edition
cFosSpeed 4.20 build 1389 -- 12-Feb-2008
+ Added support for Vista Sidebar Gadgets. See speed.gadget in the
cFosSpeed installation directory (double-click to install after first
re-boot). This sample gadget demonstrates how to create your own
sidebar gadgets. Feel free to contact us. We might be interested in
publishing your gadget on our website.
+ New language: Arabic! That makes a total of 18 languages supported.
Even more languages are downloadable from our web site, here:
http://www.cfos.de/speed/documentation/lang.htm
+ trace.txt is now in UTF-8 coding, but without a byte-order marker at the
beginning. Use e.g. notepad for viewing.
+ The gset parameter passthru can now be set to 2. This will still bypass
all shaping and packet modification logic, but not as radical as
passthru = 1. Debugging purpose only.
+ Added func_trace = 2. This will dump NDIS_PACKETS with all fields into
trace.txt. Debugging purpose only.
+ Network adapters are no longer unbound if set to "Auto". Only setting them
to "No" will force the unbind. Thanks to Andrey Chernov for his help.
+ Added a way to change and save rtt_tab's. Thanks to Darko Grskovic for
inspiration.
+ If class installer is locked, adding a route is retried every 3 seconds.
x Fixed a long-standing bug (maybe as old as v2.13): packets were sometimes
sent to the wrong network adapter. This could have happened whenever you
had more than one active adapter. This could fix problems with Hamachi,
VPN software, multiple network cards or bridging. Please test and report!
x Fixed a rare crash while loading. Maybe this crash only appeared with
certain VPN software. Thanks to Christopher Moffett for the dump file.
x Testing whether not activating the device will fix freezes after
installation under Vista.
x Cleaned up NDIS packet handling.
x Buttons in the icon skins where not working under Windows Vista. Fixed.
x Now setting 'inhibit_bridged' will immediately change 'bridged' variable.
Thanks to Velouria for the bug report.
x Some internal rewrite to fix a spurious bluescreen.
在此發佈修正的版本:)
更讓你的網路頻寬充份的被利用。
使用教學
Download
Download
inspiration.
