【軟體名稱】:CDBurnerXP 4.3.0.1977
【軟體語言】:多國語言
【軟體分類】:燒錄程式
【軟體性質】:免費
【檔案大小】:4.25 MB
【放置空間】:RapidShare/ badongo
【解壓密碼】:no
【軟體介紹】:
CDBurnerXP 是一套 免費 可用來燒錄 CD 及 DVD 的應用軟體,包括 Blu-Ray 和 HD-DVDs。 它也包含了燒錄和建立 ISO 檔案的功能,以及多國語言介面。 所有人,甚至是公司都能免費使用它。它沒有包含廣告軟體或其他相似的惡意元件。
主要功能
燒錄所有種類的碟片
音軌間包含或不包含間隔的音樂 CD
燒錄及建立 ISO 檔案
燒錄後檢驗資料
建立開機光碟
多國語言介面
Changes in Version 4.3.0.1977 - 2010-03-11:
* Added Kazakh translation
* Added Arabic translation
* Extended "Copy disc" functionality
* -tao and -sao switches for command line version
* Check for updates less frequently
* Use UDF for command line burning/ISO creation
* The CD-Text information can now be edited directly in the track list, without using the CD-Text dialog
* Updated NumediaSoft burning library (should provide a better device detection on Win7)
* Added proper error message for DRM protected files
* Re-enabled the possibility to append tracks to non-finalised audio discs (Track-at-Once only)
* Fixed inverted "Finalize" option when burning ISO files
* Fixed incorrect disc label limitation in the "Edit CD/DVD labels" dialog
* Fixed a NullReferenceException during cover printing
* Fixed log file option (file will be stored in %appdata%\Canneverbe Limited\CDBurnerXP)
* Fixed burning MDS image files
* Free space is determined incorrectly, when accessing folders which point to a different partition
* Fixed varying burning speed when burning multiple copies
* Fixed: Selecting a different burning speed has no effect when burning ISO images (again)
* Fixed: Empty CD-Text is not empty, but uses StarBurnX defaults
* Fixed: Some "track no." tags were read incorrectly (updated to BASS.NET 2.4.6.3)
需要安裝 Microsoft .NET Framework 2.0 或者更高版本!
Since CDBurnerXP 4, we use the Microsoft .NET Framework 2.0 (or any higher version) as basis for our application. If you are running Windows Vista, you already have .NET 3.0 preinstalled so there is nothing to care about. Any earlier operating system, however, requires that you install it manually.
Download .NET Framework 2.0
Download .NET Framework 3.0
*******本帖可能隱藏重要的內容需要回覆才可以完整瀏覽*******
確保下載的軟體能正常使用,請使用WinRAR 3.93 Final 版本解壓
WinRAR 3.93 - Final_正體中文版 (32 位元)
