Blu-ray to DVD II Pro 2.50 Converter - 8 MB
viet80
Info:
Blu-ray players and Blu-ray software players.
• A better video and audio effect.
• Burns more effectively and more quickly.
• Saves your desired audio track while copying Blu-ray to DVD
• Saves the audio track and subtitle you prefer while copying Blu-ray to AVCHD
• Copies a Blu-ray movie to a DVD/AVCHD movie and saves it on the harddisk drive
• Selects your desired resolution while copying Blu-ray to AVCHD
FEATURES
1. Blu-ray to DVD:
• With only one click, you can compress a Blu-ray movie to one DVD-5 or DVD-9, or two DVD-5s
• Copies a Blu-ray movie to a DVD movie and save it on the harddisk drive
• The SmartExpress HD video codec module ensures an effective and fast burn
• The SmartBurn burning engine is the most stable and fast one tested by DVD-Cloner
• Compresses the harddisk Blu-ray movie to a DVD-R/RW or two DVD-5s
• Burns the movie to more blank discs and you’ll get a better picture and sound effect ( “Blu-ray to two DVD-5” copy
mode only)
• Copies a Blu-ray movie to a DVD movie and saves it on the harddisk drive
• Supports for all DVD players and DVD software player
• Copies encrypted Blu-ray movies with the help of a third-party Blu-Ray/HD DVD Copy Helper. ( Blu-Ray/HD DVD
Copy Helper is not produced by OpenCloner Inc. OpenCloner Inc. will not be responsible for this product.) Click
here to learn more.
2. Blu-ray to AVCHD:
• With only one click, you can compress a Blu-ray movie to one AVCHD DVD-R/RW or DVD-R/RWs, which has a
better video and audio effect. *1
• “1:1 copy” can perfectly copy a Blu-ray movie to DVDs without any compress or quality loss. *2
• Copies a Blu-ray movie to a AVCHD movie and save it on the harddisk drive
• SmartBurn burning engine. It is the most stable and fast validated many times by DVD-Cloner
• Compresses a harddisk Blu-ray movie to one AVCHD DVD
• Burns the movie to more blank discs and you’ll get a better picture and sound effect Copies the harddisk Blu-ray
movie to one AVCHD DVD-R/RW or multiple AVCHD DVD-R/RWs
• Supports for all the Blu-ray players and Blu-ray software player
here to learn more.
1: AVCHD can’t be played back on DVD players. You need a Blu-ray player, like PS3, Sony BDP-S1 (1.55), Samsung
BD-P 1200 and so on, or the software player in PC, like PowerDVD.
2: Since there isn’t any compression under 1:1 copy mode, four to ten blank DVDs are needed.
Changes in Blu-ray to DVD Pro 2.50:
* HST™ – Convert quickly and effectively!
* Blu-ray to DVD II Pro 2.50 adopts the advanced HST™ Technology which will make Blu-ray to AVCHD conversion
500% faster.
代碼:
Download Link: (Rapidshare)
http://rapidshare-nz.blogspot.com/2010/03/part1_12.html
Pass: invencivel
peter2010
試過2.4好像有問題,試看看2.5的謝謝
(下載網址是不是有誤?請大大修正好嗎?) 謝謝
sjianq
感谢楼主的好东西,不知这个究竟怎么用,我每次转DVD9也是只能转一个片子,用时2个多小时,文件转完再转地2部,就不正常了,就变成1个小时,转出的文件也变小了,播放后发现没转完整,只能重装系统再转,每次重装后也只能转第一部,地2部就又不正常了,请楼主赐教,以前也下过些蓝光转制DVD9电影,不知是用什么软件转的,还带菜单,挺完整的
