軟體簡介:
BitComet 是繼 Bitspirit 之後,另一個完全整合所有 BT 下載所需功能的 BT專屬下載軟體,大幅減化 BT 下載在管理以及細部功能設定上的繁複性。除了採用與 FlashGet 相同的操作介面設計外,BitComet 本身也内建 BT 分享資源的搜尋功能,只要掌握關鍵字,馬上可以就能搜出許多檔案下載。
Change Log:
- GUI Improved: Add the function to move task downloded files to corresponding folder when change task catalog
- GUI Improved: Improve task list diaply speed
- GUI Bugfix: fix the bug that the publisher's webpage may be openned incorrectly when selecting multi-task using mouse
- GUI Bugfix: fix the bug in version 0.71 that the UPNP gateway NAT port mapping function does not work
- GUI Bugfix: fix the bug in version 0.71 that the task download rate in balloon tip is not diaplayed correctly when main window is minimized
- GUI Bugfix: fix the bug in version 0.71 that the balloon tip will not diaplay when task download finish and main window is minimized
- GUI Bugfix: fix the bug in version 0.71 that stop task while playing video may cause program crash
Download
Change Log:
Download
