BitComet 0.57 Final
sxs112.tw
What's New:
- GUI Improved: add boss key: Alt+`
- GUI Improved: embeded web view was improved
- GUI Improved: Task Properity Diaglog can be resized or maxmized now
- GUI Improved: option to disable the prompt window when adding torrent
- GUI Improved: enable multi-selection when open torrent files
- GUI Improved: task list now support sort
- GUI Improved: add seeding task catelogy
- GUI Bugfix: fix the copy paste problem in embeded IE
- GUI Bugfix: never prevent windows from entering suspend mode if the computer is running on batteries (Thanks B. Larg)
- GUI Bugfix: Save location reset to default upon changing encoding method. (Thanks ericbo)
- GUI Bugfix: Incorrect time left if more than 24 hours (Thanks u1ookingatme)
- GUI Bugfix: the max value of half-opened tcp can't be changed to smaller value
- Core Bugfix: fix a upload selection bug which may affect download speed
- Core Bugfix: auto stop may not work if enable auto checking after finished
- Core Bugfix: possiblely fix the tracker download reporting bug happens in TB, etc
- Core Bugfix: fixed NAT Traversal rate can not be accurately limited
- Core Bugfix: Can not create directory when change priority for running task (Thanks maxbkk)
- Core Bugfix: IP rules do not effact in NAT Traversal connections(Thanks tianle)
- Core Bugfix: add new task waiting queue, close bc, the file priority lost(Thanks hdll)
- Core Bugfix: Hash Checking queue does not work (Thanks njiayu)
- Core Bugfix: UDP tracker retry interval keeps to be 10s
下載處
ctxultra
雖然我很少用 bt 這類的軟體, 不知道其它 bt軟體的情況是怎樣
不過想不到 bitcomet 居然加了 boss key 這種東西 :PPP:
gamewed
造訪網站
官網真是啟智...下載點和鏡像站都還是.56的...可是官網放的是.57的圖....
glbi
潛水會員
造訪網站
樓主放的的確是0.57版
官網上目前我找不到0.57版的下載點
Victory
小弟我載完了耶
官網放的應該是對的吧
看檔名是1.57的沒錯
還沒安裝囁
因為還在下載啦 B)
Zeke
好用的東西
感謝分享
c1724
終於出新版了,0.56已經用了好久了!!
RaySoul
這個帳號是空號
http://www.p2pforums.com/viewtopic.php?t=10942
http://dl.pconline.com.cn/html/1/9/dlid=11...id=1&pn=0&.html
更新日志
v0.57 2005.3.5
界面改进: 增强了老板键 Alt+`
界面改进: 增强了内嵌的浏览器
界面改进: 任务属性对话框可调整大小或最大化
界面改进: 允许添加任务时不出现提示窗口
界面改进: 打开torrent文件时允许多选
界面改进: 任务列表支持排序
界面改进: 上传任务增加分类管理
界面改进: 增加IE收藏夹
界面修正: 用电池供电时不阻止系统进入挂起/休眠即时该选项已经打开。
界面修正: 修正了IE窗口剪贴板操作无效的问题
界面修正: 当修改torrent编码时存储位置被重置(感谢ericbo)
界面修正: 剩余时间大于24小时的时候显示不正确(感谢u1ookingatme)
界面修正: Torrent备注中多加空行的问题
界面修正: 最大同时连接发起不能设置得更小的问题
界面修正: 广告菜单语言变化时的重载问题修正
核心修正: 多个任务一起重新检查完整性时,检查完前一个任务不会自动检查下一个任务(感谢njiayu)
核心修正: UPNP设备/服务查找算法修正
核心修正: 5Q教育网优化
核心修正: 修正了打开下载完成后检查可能导致自动停止失败的问题
核心修正: 任务运行时修改优先级不能正确创建文件目录(感谢maxbkk)
核心修正: IP规则在内网互联中失效的问题(感谢tianle)
核心修正: 新添任务如果在排队中关闭BC导致优先级设置丢失(感谢hdll)
核心修正: 修正一个上传选择算法中的问题,可能解决部分用户下载过慢的问题
核心修正: 修正了UDP服务期的重试间隔保持10s的问题
相关文章 : 将BT进行到底-BT客户端工具全收集
相关文章 : BT下载速度之战:Bitcomet对决比特精灵
cutechris
;) 感謝提供新版BT軟體,期待好一段時間了,THKS!!
