ATI Tray Tools 1.0.5.877
sxs112.tw
Overclocking for X1300/X1600/X1800/X1900 disabled in this release due to lack of information and without hardware sample in my laboratory.
Fixed ATT loading bugs in Windows 2003 Server when Hardware acceleration is disabled.
Fixed bug in 3D Scanner when ATT enters into infinite loop
Updated new "Apply 3D settings" method.
Support for TRUFORM now disable if detected Catalyst version more than 5.9
Improved Auto FAN Control method for FinTek sensors. Now you can manually adjust RPM in temperature table.
Updated Monitoring Graphs module to support new monitoring sources
Updated kernel mode I2C procedures.
Geometry Instancing now can be included in 3D profiles
Reverted color correction procedure to old type, when you can adjust color individually for different displays.
Updated internal benchmark module. Now benchmark will render two scenes, first in max speed mode and second one in max quality mode. And benchmark will be run on full screen mode (1024x768x32bit)
Updated Color calculation procedure. All color profiles must be recreated.
Updated Sound Recorder. Now you can configure input source and level of recording signal directly in ATT.
Added temperature monitoring, voltage monitoring and fan control for R5xx boards (X1600/X1800/X1900)
Added new X1600 and X1900 DevieID's in database.
Added deinterlacing method adjustment in Video Overlay module
Added 3:2 pulldown support
Added support for new TV Video standards
Added voltage monitoring for video board with FinTek sensor (Mostly used by ASUS)
Added option to change Jpeg quality for screenshots.
Updated start up modes option. Now you can select how ATT will start with Windows. Via registry or via StartUp menu folder.
Update "Switch rotation" hot key. Now it will switch between 0 and 180, or 90 and 270 and vice versa
Updated Injection code procedures to prevent games from crash if used with "fake" Direct3D9 dll file.
Guru3D
Victory
有下有回
來更新囉
感謝囉^^
