顯示器 ASUS PQ321Q 第一台4K螢幕開賣
ASUS最近宣布第一款4K螢幕「PQ321Q 」即將開賣,國外已經開始接受預定,要價3499美元,折合台幣大約是105,000元。
ASUS PQ321Q 的解析度為3840x2160,相當於4顆HD的螢幕結合,尺寸為31.5吋,採用IGZO面板,亮度最高為350cd/m2,反應時間為8ms(GtG),可視角為176/176度。輸入的部份有DisplayPort、2個HDMI、RS-232C,另外有2個2W的立體聲喇叭、3.5mm 輸入、3.5mm 輸出。
ASUS PQ321Q 規格表
Model: PQ321Q
DISPLAY PANEL: 31.5" (80.1 cm), 3840x2160, IGZO WLED Backlit, 0.182mm Pixel Pitch
DISPLAY COLORS: 1073.7 million colors /100% sRGB/80% NTSC CIE1976 / 72% NTSC CIE1931
BRIGHTNESS: Min < 80cd/m2 Max: 350cd/m2
CONTRAST RATIO: Native 800:1
VIEWING ANGLE (CR 10): Horizontal: 176° / Vertical: 176°
RESPONSE TIME: 8ms (GTG)
LOOK-UP TABLE: 14 bit LUT
COLOR AND GAMMA: Standard, Vivid, and sRGB color modes. 18 levels of color temperature 3K-10K in 500K increments.
5 Gamma Modes: 1.8, 2.0, 2.2, 2.4, Standard
VIDEO I/O: DisplayPort 1.2, 2x HDMI 1.4, RS-232C
AUDIO I/O: 2W x 2 stereo, 3.5mm In, 3.5mm Out (for HDMI and DP only)
HEIGHT ADJUSTMENT: 0 ~ 150mm / 0 - 5.9"
PIVOT / SWIVEL / TILT: Swivel +45° to -45° / Tilt +25° to -5°
FEATURES: Picture-by-Picture, Screen/OSD Rotate, Kensington Lock
VESA WALL MOUNT: 100mm x 100mm
DIMENSION (WxHxD): 750 x 489 x 256 mm (with stand) / 29.5 x 19.2 x 10 inches (with stand)
NET WEIGHT: 13Kg / 28.6lbs
REGULATORY APPROVALS: UL/cUL, FCC, ICES, RoHS, WEEE, Windows 7 and 8 WHQL
MAX. POWER CONSUMPTION: Operating 93W / Standby < 6W / Low Power < 1W
ACCESSORIES: DisplayPort cable, Power Cord, RS-232C conversion cable, Warranty card, Cable Tie
MSRP: $3,499 USD
timma
跟一台國產180水冷機車同價;0a155245;
opendoc
一年能賣幾台?現在的game 有支援?
cisco2012
只能講! 代工~ 真是很趕!! 積極的搶灘!! 恐怕成為!! 曇花一現!! 還是等等!! 專業的面板大廠的!!!良率提升!! 大量生產吧!!
willyjason
3,499 U.S 約新台幣 105,053
我等兩年後,跌爆了再考慮換。
Toby6714
用這種解析度完應該會爆掉八
mikehs14
根本天價...不過應該是未來的趨勢吧
Rody
解析度真的很嚇人,不過目前應該很少媒體會支援那麼高的解析吧~
348824880
10萬5是要賣給誰..2160p..
繼續用1080p;face0;
