Asus Commando如何上533以上 1:1的基本概念
狂少
Bulletproof Themer
小弟先來po一下commando的的基本設定
先說抱歉,只好原文po出
因為super pi那篇文章有很多要做解釋!!
超頻是國際共通語言...大家程度都不錯
忍耐一下吧
測試會晚點貼:D
I just got this board and have it go through some time.
It's quite a nice board and easy to get on high fsb: high ram freq.;
I just would like to share my settings for those who still not really get on the right track,
therefore, I won't post the board and introduce those rich functions.
let's just go directly to the parts you guys concern about.
here are all the tweaking settings::
1. Here I have to suggest you if you have meter, go measure every points; because you need to trust what you measure not those numbers from motherboard monitor of BIOS. From the PIC below, besides Vcore due to Vdroop that I need to set 1.5v to obtain 1.43v, the others voltages are way greater than what I set here.
here we have all the memory parameters setting; be sure that your ram can handle those settings, or you can give safe settings first. Most likely Team Group's
DDR800 3-3-3-8/DDR1000 5-4-4-12 can do that like my settings here.
the least important page of bios;
remember that you will need to disable those annoying settings here in order to overclock well.
Later I will have some super pi and 3d bench post.:up:
OPB
狂少
Bulletproof Themer
ok folks, here are some 1st step of getting super pi ,
pretty much just look at the clock gen and newer memset,
timings are all set as pretty tight, so you know how to adjust them.:)
violet
沒事愛閒晃的路人
嗯~不知道在技嘉的版子上~
能不能請狂爺稍微解說一下呢~
Second2
狂少大又來教學了~讚讚讚!請教一下狂少大,這些能不能通用於P5B-D呢?
有幾個地方英文看不太懂,希望懂得網友們可以把它翻成中文嗎?
例如:BIOS的第1張的SB部分是不是說可以不用管它?
再請教狂少大一下,那些細部參數是不是在RAM跑很高的時候才能用,像是DDR2-1066以上...
還是說只要這樣設定不論多少都可以呢?這樣的參數算是很緊了對吧!?
hyde211
狂爺的測試又來啦
不多說
先推在說~~~;cheer2;
狂少
Bulletproof Themer
沒錯,第一張是這樣
如果你沒用到PCI-e,那當然不要加啥壓
細部參數一定要懂他的道理
像TRRD.這明明可以不用到10
可是為啥會在bios設10?
不是Asus錯哦
那進windows又嘩拉降到4...
想想NV680的trrd是多少?....1耶...
Second2
沒錯,第一張是這樣
細部參數一定要懂他的道理
像TRRD.這明明可以不用到10
可是為啥會在bios設10?
不是Asus錯哦
那進windows又嘩拉降到4...
1...:eek: 太緊了吧!不過ASUS進WIN會降到4嗎?怎麼我的還是顯是10阿?:confused:
頓時覺得參數還真神奇,難怪DFI會比ASUS快,原來一個是2一個是10阿!;em28;
不過狂少大,應該不會有人不用PCIE吧!那不就不插顯示卡?;rr; 我不會設定,所以我都設AUTO:PPP:
hyde211
狂爺你好
想跟你請教一下
我的板子是Striker Extreme NV680i
CPU是 E6600 oc 333*9
RAM是 創見 D9GMH DDR2-667 1GB*2 -> oc 800 1.9V
參數手動設定
因為本身對參數設定還不太了解
所以我都把每一項條到最低至不當機至可以跑pi & sp2004
如下
CL----- 4
RCD--- 4
RP----- 4
RAS--- 4
CMD--- 1
RRD--- 2
RC--- 12
WR----- 5
WTR--- 7
REF --- 1
RD ----- 5
RFC--- 23
AL ----- 1
想請教的是我參數的部分有沒有哪裡要改進
例如哪個部分要調高一些
因為參數關聯性我還不是很懂
所以想跟你請教一下
謝謝你耐心看完:PPP:
tonyyenn
謝謝狂爺的測試和分享..又學到知識, 謝謝你
狂少
Bulletproof Themer
狂爺你好
想跟你請教一下
CPU是 E6600 oc 333*9
參數手動設定
因為本身對參數設定還不太了解
如下
CL----- 4
RCD--- 4
RP----...
我是這樣設:
CL----- 4
RCD--- 3
RP----- 3
RAS--- 4
CMD---2
RRD---1
RC--- 14
WR----- 3
WTR--- 6
REF --- 1
RD ----- 5
RFC--- 20
AL ----- 1
這是跑ddr1200, 4-3-3 2t, 2.45~2.5v
一般說來,穩定性的關鍵是在TWTR和TRRD; TRC和TRFC則是偏向performance較多
所以TRRD可以放到2或3即可; TRC 12就有點太緊
** Second兄
asus的trrd進windows不會自動變
那是我舉例可以調4
