请教一下各位高手, 这两款散热器哪一个比较好? Arctic freezer 13 or Cooler master 212 plus
Arctic freezer 13 http://www.arctic.ac/en/p/cooling/cpu/3/freezer-13.html
Limited Warranty 6 years
Dimensions (Packaging) 126 L x 103 W x 140 H mm
Dimensions (Product) 123 L x 96 W x 130 H mm
Fan (mm) 92
Noise Level (Sone) 0.5
Cooling Capacity (Watts) 200
Rated Fan Speed 600 - 2000 RPM, (PWM Controlled)
Airflow 36,4 CFM / 61.8 m³/h
itemnumber UCACO-FZ130-BL
UPC 0872767003781
Weight 0.8 kg
Cooler master 212 plus http://www.coolermaster.com/product.php?product_id=6603
Dimension 120 x 79.7 x 158.5 mm (L x W x H)
Weight 626g
Heat Sink Material Aluminum fin / 4 heat pipes
Fan Dimension (W / H / D) 120 x 120 x 25 mm
Fan Speed 600 - 2000 R.P.M. (PWM)
Fan Airflow 21.2 - 76.8 CFM
Fan Air Pressure 0.40 - 3.90 mmH2O
Bearing Type Long life sleeve
Fan Life Expectancy 40,000 hours
Fan Noise Level (dB-A) 13 - 32 dBA
Connector 4-pin
想使用在AMD X6 1075T 上...
谢谢..
Fan (mm) 92
UPC 0872767003781
Weight 0.8 kg
Weight 626g
Connector 4-pin
谢谢..
