【軟體簡介】:
Antivirus Remover 是一套簡單易用的應用程式,讓您可以移除您電腦上安裝的防毒軟體,並從系統登錄或暫存檔案中清理任何痕跡。Antivirus Remover 是一套可靠的安全工具,讓您能將舊的防毒軟體從電腦中完全移除而不會與新安裝的防毒軟體相衝突。
下載解除安裝工具
Antivirus Remover 是一套支援的應用程式,讓您能夠快速下載多個防毒軟體其適當的解除安裝程式。這個程式將列出所有支援的防毒軟體和它們的解除安裝程式的直接連結。
當您在您的電腦上安裝程式時,安裝程式檔或軟體本身可能會建立捷徑、暫存檔案、報告或其他相鄰文件,並將它們儲存在不同的位置。許多這些檔案很難到達,尤其是如果它們儲存在電腦的系統登錄中。不過,為了安全地刪除防毒軟體,您需要找到所有這些檔案並將它們刪除。
多個防毒軟體個別解除安裝工具
每個 Antivirus Remover 支援的防毒軟體需要特定的解除安裝程式檔,這就是為什麼軟體針對每個程式提供了單獨的下載連結。您只需按一下所需的連結,Antivirus Remover 就會幫您下載解除安裝程式並在您的電腦上執行它。
將顯示一個對話方塊,通知您所選的防毒軟體版本將被移除。單一的解除安裝程式可以刪除比如防毒軟體的標準、專業、Plus、家用、伺服器或免費版本。
您電腦保護的安全工具
Antivirus Remover 可以在正常模式下運行,但建議您在安全模式下(含網路功能)執行,以確保正確的刪除過程。這就會要求您將電腦重新啟動並在安全模式下(含網路功能)啟動。因此,Antivirus Remover 可以保證完全刪除任何所支援的安全性軟體,以保護您的電腦,避免當安裝一個新的、不同的防毒軟體時會與未移除乾淨的舊防毒軟體相衝突。
Antivirus Remover is a simple to use application that enables you to remove the antivirus software installed on your computer and clean any trace from the system registry or temporary files. Antivirus Remover is a reliable security tool and allows you to make sure your former antivirus is not in conflict with a new one.
Download the uninstalling tools
Antivirus Remover is a support application that enables you to quickly download the proper uninstallers for a multitude of antivirus software. The program lists all the supported antivirus software and the direct links that host the necessary files for their removal.
When you install a program on your computer, the installer file or the software itself might create shortcuts, temporary files, reports or other adjacent documentation and save them in different locations. Many of these files are difficult to reach, especially if they are saved in the computer's registry.
However, in order to safely remove the antivirus, you need to find all these files and erase them.
Individual uninstalling tools for multiple antivirus software
Each antivirus supported by Antivirus Remover requires a specific uninstaller file, which is why the software offers you separate download links afferent to each program. You simply need to click on the desired link and Antivirus Remover can download and run it on your computer.
A dialog box is displayed, notifying you that which editions of the selected antivirus are subjected to removal. A single uninstaller can remove, for instance the standard, professional, plus, home, server or free editions of an antivirus software.
Security tool for your computer’s protection
Antivirus Remover can run in normal mode, but it is recommended that you run it in safe mode with networking, in order to ensure proper removal process. This requires that you reboot the computer and start it in safe mode with networking. Thus, Antivirus Remover can ensure a complete removal of any of the supported security software, in order to protect your computer and avoid conflict when installing a new, different antivirus.
【軟體名稱】:Antivirus Remover 2.35-幫您完全移除電腦上安裝的防毒軟體
【軟體大小】:872 KB(解壓後)
【軟體格式】:RAR
【作業系統】:Windows XP / Vista / Vista 64 bit / 7 / 7 64 bit / 8 / 8 64 bit / 10 / 10 64 bit
【官方網站】:http://www.wilderssecurity.com/threads/antivirus-remover.352955/
【語言種類】:正體中文
【正體中文編譯】:丹楓
免責聲明:
本人所提供的中文化軟體僅供各位下載測試使用而不提供軟體相關使用教學說明。
1.本站所有文章全文轉載前請先取得授權,並需註明出處及加上超連結。
2.倘若軟體屬於共享試用軟體,下載軟體試用後請在「產品試用期」到期時移除。本人不對所提供的共享試用軟體負任何法律責任。
3.軟體下載使用前請自行考慮清楚,本人不對因使用軟體而導致電腦產生的任何問題負責,欲使用請自行承擔風險。
4.所提供的中文化軟體大多為便攜免安裝版,不會對您的電腦做任何修改。
5.本人僅保證自己所上傳的檔案無自行添加任何惡意程式代碼,至於其他人下載本人提供的檔案後再自行包裝上傳其他免空有可能添加任何惡意程式代碼的危險,因此從其他人所提供的免空下載本人所中文化的程式請自行承擔風險。
6.本站不提供「破解檔」、「註冊機」或「註冊碼」等資訊,請勿留言索取檔案。
載點:(解壓密碼:zhtwnet.com)
下載連結→ [按此下載]
