AMD FX-8300 and FlanK3r
FlanK3r
Finally is the day of FX mania.
HWInfo and information about temps, voltage of first tested chip - this is FX-8300
At stock is FX-8300 in performance near the older FX-8150. Vishera is better in IPC and specially in games.
Cinebench R10 and R11.5
For all benchmarks I used decent OC at 4762-4763 MHz, but this clocks are not full stable I mean. So some average CPU....
4762 MHz benchable OC, Sisoft Sandra
Wprime 1024M with win7 64-bit with 2CU/4C software (not hadware shutdown)
wprime 1024M with 4CU/4C. With software assignment of process
Old one 3D Mark2005, GPU decent OC only
AIDA 64 memory bandwith (write, read, copy) at 4763 MHz and 2162 MHz DDR3 RipjawsX
AIDA CPU Queen
AIDA 64 Photo
AIDA 64 CPU AES
AMD Overdrive benchmark
Cinebench R10
hmmm, new Cinebench R15 at 4763MHz
HWBOT PRIME benchmark
MaxxPI 32M, scaling much better than old x87 superpi :)
Multicore Pi benchmark 4763 MHz
Nuclearus benchmark
One part of ScienceMark
Do you know ROG benchmark? He is long, stressed one part very well and including work with photo, video compression and multitasking
The maximum
Max Cinebench was able aroud 4815 MHz only :-(. This chip was very hot, but working OK up to 80 C in Coretemp!
Superpi 32M at 4965 MHz
And now something about quality of CUs. I tried it with SUperpi 32M and later with validation.
CU1 the best one
CU2 average
CU3 average
CU4 the worst
Superpi 1M max was around 5117 MHz and I want not used more than 1.55V for this chips
Validation 5317 Mhz with screenshot :)
