【軟體名稱】:AIMP 3.50 Build 1236 Beta 2 ~ 免安裝
【軟體語言】:多國語言
【軟體分類】:播放程式
【軟體格式】:自解壓縮檔
【檔案大小】:7.30 MB
【放置空間】:depositfiles / solidfiles
【解壓密碼】:
AIMP 是一個長得很像傳統WinAMP的音樂播放器,不過 AIMP 功能相當多元、擴充性也很不錯,除了該有的EQ等化器、播放時的視覺特效、可更換、自訂佈景主題...之外,他的播放清單跟foobar2000一樣可以很方便的用「多頁籤」的方式瀏覽、切換,適合給喜歡自己編輯一堆歌單來聽的人用。實際操作起來又跟WinAMP般簡單、直覺。
除此之外,AIMP 內建了一堆相當實用的小功能,譬如說可以讓我們自行設定自動關機時間,看是要用倒數計時的方式播到時間到之後就關機,或在指定時間讓電腦自動關機、休眠、停止播放或關閉 AIMP 程式。甚至也可以在播放清單裡的歌曲播完之後自動關機或停止播放,相當方便!
另外AIMP內建一個相當方便好用的「DSP管理器」可以讓我們自行調整Echo回音效果、Chorus音效、現場演唱特效、Flanger、立體聲強化特效、音量正常化功能...等等。更讚的是內建了「消除人聲」的功能,可以讓我們把一般流行歌曲拿來當卡拉OK唱!
更神奇的是,AIMP還內建了一些相當特別的延伸功能,除了可以調整音頻高低(無段式調Key)、還可以「調整歌曲播放速度」,讓我們用更快或更慢的節奏來聽歌,對於想要用特別方式來播歌、聆聽歌曲細節的人來說,真的還滿方便的。
Changes in AIMP 3.50 Build 1236 Beta 2 (07.03.2013):
* Audio Converter: Tags are now stored to WMA and WavPack formats via AIMP tags engine
* Audio Converter: Only common information about the tracks is now stored to the file tags during “All-to-one file” encoding mode
* Player: Response time of the window in “desktop toolbar” mode during adding files via drag-n-drop operation has been decreased
* Player: Playlists reading speed has been increased by 25%
* Skin Engine: Compatibility with old skins has been improved
* Skin Engine: Rendering speed has been increased due caching of the background elements
- Fixed: Installer doesn’t create shortcuts under Windows 8
- Fixed: Installer – update mode doesn’t work
- Fixed: Simple Scheduler – the state of “shutdown the computer” option isn’t stored
- Fixed: Player – few folders without spaces in the names cannot be added to the player via command line
- Fixed: Player – the plug-ins table jumps to beginning after any plug-in is unloaded
- Fixed: The tag editor stores two copies of cover art to the file in FLAC format
- Fixed: Skin Engine – information in QFI isn’t refreshed in some cases
- Fixed: Skin Engine – maximized window reduces its size after AIMP restart
- Fixed: Playlists Managing – preview for few selected playlists doesn’t work correctly
- Fixed: Audio Library – all tracks from set are added to the audio converter regardless of which of them were selected
- Fixed: Small bugs and defects
