【軟體名稱】:AIMP 3.50 Build 1224 Beta 1 ~ 免安裝
【軟體語言】:多國語言
【軟體分類】:播放程式
【軟體格式】:自解壓縮檔
【檔案大小】:7.30 MB
【放置空間】:depositfiles / solidfiles / Rghost
【解壓密碼】:
AIMP 是一個長得很像傳統WinAMP的音樂播放器,不過 AIMP 功能相當多元、擴充性也很不錯,除了該有的EQ等化器、播放時的視覺特效、可更換、自訂佈景主題...之外,他的播放清單跟foobar2000一樣可以很方便的用「多頁籤」的方式瀏覽、切換,適合給喜歡自己編輯一堆歌單來聽的人用。實際操作起來又跟WinAMP般簡單、直覺。
除此之外,AIMP 內建了一堆相當實用的小功能,譬如說可以讓我們自行設定自動關機時間,看是要用倒數計時的方式播到時間到之後就關機,或在指定時間讓電腦自動關機、休眠、停止播放或關閉 AIMP 程式。甚至也可以在播放清單裡的歌曲播完之後自動關機或停止播放,相當方便!
另外AIMP內建一個相當方便好用的「DSP管理器」可以讓我們自行調整Echo回音效果、Chorus音效、現場演唱特效、Flanger、立體聲強化特效、音量正常化功能...等等。更讚的是內建了「消除人聲」的功能,可以讓我們把一般流行歌曲拿來當卡拉OK唱!
更神奇的是,AIMP還內建了一些相當特別的延伸功能,除了可以調整音頻高低(無段式調Key)、還可以「調整歌曲播放速度」,讓我們用更快或更慢的節奏來聽歌,對於想要用特別方式來播歌、聆聽歌曲細節的人來說,真的還滿方便的。
Changes in AIMP 3.50 Build 1224 Beta 1 (31.01.2013):
+ Common: Performance has been increased
+ Common: Player no longer supports configuration files from AIMP2
+ Common: Added support of long pathname (more than 260 characters), only for Windows Vista and newer
+ Common: Settings in options dialog has been regrouped
+ Common: Added an ability to split files by chapters (OGG, OPS, M4A and M4B are supported)
+ Sound Engine: Added support for i32v24 sample format
+ Sound Engine: Now player has separate settings for crossfading in manual and automatic switching modes
+ Sound Engine: Equalizer has been improved – now all frequencies are processed between sliders
+ Skin Engine: Potential abilities are extended
+ Skin Engine: An ability to switch off spectrum animation for playable track
+ Skin Engine: An ability to dock window to the top and bottom screen edges
+ Player: Hotkey for the “Reload data from pre-image” command has been added
+ Player: Hotkeys for executing the “Bookmarks Manager” and “Equalizer” dialogs has been added
+ Player: Hotkeys for set mark to playable / selected files has been added
+ Player: Confirmation for the remove equalizer preset operation has been added
+ Player: Equalizer settings has been added to the DSP Manager dialog
+ Player: Now files merge into one queue, when send it to a removable device
+ Player: Added Drag-n-Drop support for the Bookmarks Manager
+ Player: The queue of shuffle playback is now stored on the application closing
+ Player: Playlist tab hint now contains information about playlist content
+ Player: Managing Playlists – added an ability to browse content of closed playlist (with search ability)
+ Audio Converter: Hotkey for start conversion process has been added
+ Audio Converter: Added an ability to save path structure during conversion process
+ Audio Converter: OPUS Encoder has been added
+ CoverArt Downloader: Caching of downloaded files for current work session
+ CoverArt Downloader: Click on image now opens it in external application
+ Scheduler: Alarm Clock – added an ability to execute action after pre-set time period
+ Scheduler: Alarm Clock – added an ability to set playlist as alarm clock ringtone
+ Tag Editor: The “File Size” column has been added
+ Tag Editor: Added an ability to resize window of “Presets Editor” dialog
+ Tag Editor: Rename files – added an ability to replace / remove selected characters
+ Tag Editor: Rename files – bilateral transliteration has been added (Russian – English)
+ Tag Editor: Rename files – new design
+ Tag Editor: Added support of “BPM”, “Disc Count” and “Publisher” tag fields
+ Tag Editor: Added support of OPUS format tags
+ Tag Editor: Added an ability to calculate BPM (powered by SoundTouch Library)
+ Audio Library: Mark reading speed has been increased by 10 times
+ Audio Library: Added an ability to display rating instead of mark, if mark is not set
+ Audio Library: Added an ability to switch off automatic jump to next track during playback
+ Audio Library: Added an ability to send files to playlist
+ Audio Library: The “BPM”, “Composer”, “Publisher” and “File Format” columns has been added
+ Audio Library: Added an ability to add files to data base via Drag-n-Drop
+ Audio Library: Added special context menu for cells of the “Labels” column
+ Audio Library: Hotkeys for playback control has been added
+ Audio Library: New design of the “Labels Manager” dialog
+ Custom Controls: Context menu – added an ability to scroll items via mouse wheel
+ Custom Controls: Context menu – auto scrolling to selected item on menu popup
+ Custom Controls: Now you can switch between tabs via Ctrl+Tab and Ctrl+Shift+Tab / Ctrl+PageUp and Ctrl+PageDown shortcuts
+ Custom Controls: Scrollbar – added an ability to jump to position under mouse cursor via mouse click with pressed Shift key
+ Custom Controls: ListView and TreeView – per-pixel scrolling has been added
