【軟體名稱】:AIDA64 Extreme Edition 2.60.2127 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:14 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v2.60.2127 Beta 更新紀錄:
* Hardware Monitoring / new items: DIMM EF, DIMM GH voltage
* listview column widths restoring
* extended CPUID features (ADCX / ADOX Instruction)
* extended CPUID features (RDSEED Instruction)
* extended CPUID features (Supervisor Mode Access Prevention)
* Intel Processor Number detection for Core i7-3630QM, 3970X
* identification of DDR3-2666 memory modules
* sensor support for Nuvoton NCT7904D sensor chip
* motherboard specific sensor info for Gigabyte H61MA-D2V, H61MA-D3V
* motherboard specific sensor info for Supermicro X9DA6, X9DA7, X9DAE, X9DAI
* extended GPU information for nVIDIA GeForce GTX 660 (GK106)
* fixed: chipset information for AMD K10 IMC, K11 IMC
