【軟體名稱】:AIDA64 Extreme Edition 2.50.2013 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:13.6 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v2.50.2013 Beta 更新紀錄:
* SensorPanel / Preferences in System Tray icon right-click menu
* Preferences / last page restoring
* improved uptime measurement under Windows 2000+
* Intel Processor Number detection for Celeron G540T
* Intel Processor Number detection for Pentium G640, G640T, G860T, G870
* USB-IDE bridges support disabled on a few flash drives
* disabled I2C bus #5 scanning on AMD Radeon HD 79xxM
* monitor information / improved vendor and model name detection
* motherboard specific sensor info for Asus P8B75-M LE, P8B75-M LE Plus
* motherboard specific sensor info for Gigabyte G41MT-ES2H, G41MT-ES2L
* fixed: Preferences / HW Monitoring / Alerting / Battery voltage limits configuration
* fixed: Logitech LCD / graph auto-scaling
* fixed: Network / Windows Network / network adapter index detection
* fixed: SPD information for Noname 128M PC66 modules with bad CRC
