【軟體名稱】:AIDA64 Extreme Edition 1.85.1639 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:12.7 MB
【檔案類型】:ZIP壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.85.1639 Beta 更新紀錄:
* identification of AMD FX-xxxx (aka Zambezi)
* TDP limit detection for AMD K15
* Intel Processor Number detection for Core i7-2700, 2700K
* improved chipset information for AMD K15 IMC
* motherboard specific sensor info for Asus M5A88 Series
* motherboard specific sensor info for Asus M5A97 Series
* motherboard specific sensor info for Asus P8Z68-M Pro
* motherboard specific sensor info for Gigabyte A55M-S2H(P)
* fixed: last page restoring
* fixed: Windows Devices enumeration under Windows 95
* fixed: screen shot saving in 256-color mode
* fixed: Intel Centrino Mobile Technology compliancy tests
* fixed: Engineering Sample detection for AMD K15
* fixed: motherboard specific sensor info for ASRock P67 Extreme3/4/6 Series
* fixed: motherboard specific sensor info for ASRock Z68 Extreme3/4/7 Series
* fixed: motherboard specific sensor info for Asus P8Z68 Deluxe, P8Z68-V Series
