【軟體名稱】:AIDA64 Extreme Edition 1.85.1604 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:12.7 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.85.1604 Beta 更新紀錄:
* Logitech LCD / simple sensor item
* SensorPanel / simple sensor item
* Display / GPGPU / support for APP SDK v2.5
* identification of Intel Atom E6xx (aka Tunnel Creek, Stellarton)
* identification of Intel Atom Z6xx (aka Lincroft)
* improved support for Intel Cedarview processors
* preliminary support for AMD K14.1 (aka Krishna, Wichita) processors
* Intel Processor Number detection for Atom Z510P, Z510PT, Z520PT, Z530P
* chipset information for Intel Topcliff EG20T
* chipset information for Intel Whitney Point SM35
* extended chipset information for Intel Poulsbo UL11L, US15L, US15W
* HD Audio codec information for Intel Whitney Point SM35
* fixed: OpenGL information with AMD Catalyst 11.8 driver (static linking of OPENGL32.DLL)
AIDA64 Extreme Edition 1.85.1600 Final
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘
感謝支持!也別忘了支持正版唷!
